Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 07-06-2016, 12:25
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
[FRC Blog] The 2016 Season, by the Numbers 2
Posted on the FRC Blog, 6/7/16: http://www.firstinspires.org/robotic...-the-numbers-2
Written by Kevin O'Connor, Robotics Engineer.
One of the under-the-hood features of the FRC Control System software is a system called Usage Reporting. This system tracks what WPILib objects are created in each team's code and reports the data back to FMS when the robot is connected to the field. This data helps FIRST and our Suppliers understand how teams are using the Control System which can give us insight into things such as adoption of new features or usage of legacy classes.
Here are a few numbers from the data that teams may find interesting:
152,572
The total number of Usage Data records captured by FMS
22,607
The total number of motor controllers used on 2016 robots
6,402
The total number of USB input devices used to control those motors
2,156
Total Encoders used to get feedback from those motors
1,4021
The number of teams that used pneumatics (with the PCM) on their 2016 robot
764
The number of USB cameras streamed back to the Driver Station
489
The number of Digital Outputs used to control non-actuators (lights, sensors, etc.) on 2016 robots
17
The number of Analog Outputs used to control non-actuators (sounds, lights, etc.) on 2016 robots
The number of teams using the GearTooth sensor class which was made for the GearTooth sensors from the 2006-2008 KOP
The complete processed data set can be found here.
A few notes on this data:
- The data has been semi-anonymized. Team numbers have been replaced with rookie years and the data has been resorted so teams are not in order by team number.
- We can only track the objects teams create in code. If you create extra motor controllers that aren't on your robot2, they will still be captured by this system. If you create motor controller objects of the wrong type, that wrong type will be captured by this system.
- Counted objects and TRUE/FALSE show the largest number of any given object used in any one match (i.e. if a Robot had 2 Encoders in match 1 and 3 Encoders in match 7, 3 will be reported). Language and Framework report what was used in the last recorded match.
- Some objects naturally result in double counting (Encoders use Digital Inputs)
1Compressor may not show for C++ and Java teams that didn't use the Compressor object. Counting the # of teams that had > 1 Solenoids is a more accurate count of teams using pneumatics.
2Example: 43 teams report more than 4 relays with only 4 relay ports on the roboRIO.
Unread 07-06-2016, 12:46
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Re: [FRC Blog] The 2016 Season, by the Numbers 2
So how do we get more encoders on more motors?
Unread 07-06-2016, 12:49
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Require 2 encoders to be declared per motor. Because 2 > 1.
#2encoders
Unread 07-06-2016, 12:50
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Those numbers are really cool and interesting to go through.
One thing to remember is that Encoders hooked up through CAN Talons would not show up. I saw a decent amount of teams doing that this year, which would probably help raise that some more. But I do agree more teams need more encoders or potentiometers, as that greatly increases the performance of robots.
Team 4488 - Mentor 2013-2016
Unread 07-06-2016, 12:54
Flywheel Police
It also probably isn't taking into account optical sensors used as counters for shooter wheels.
Unread 07-06-2016, 12:56
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I think the key to this is figuring out how to make tuning the PID loops easier. We've been using encoders and potentiometers with PID loops for years, yet it still takes our programming team a ridiculous amount of time to get each one tuned correctly. There just isn't enough time to get them set up correctly most years, and even though we put them on the robot and try to get them working, it seems like we end up commenting them out when we get to competition and have run out of time to get them working.
Plus, the USDigital encoders that we've always used have such small wires... it seems we're always breaking one or more of them!
2016: Lake Superior WFFA
Unread 07-06-2016, 13:03
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Once you go Grayhill, you never go back.
Depends on the application. If I have a 2 position arm or mechanism that doesn't need precise operation, I can get away with just using a limit switch. And I'm sure that you don't really need encoders for intake rollers, either; but teams should definitely be using them for their drivetrain and shooter wheels. (Hell, 1648 used a banner sensor and a piece of retro-reflective tape on a belt for our shooter's feedback)
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 07-06-2016, 13:14
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Coolest thing I saw:
Lang	Count	Percentage
C#	1	0.03%
C++	435	13.97%
Java	1526	49.00%
LabVIEW	1116	35.84%
Python	33	1.06%
Unknown	3	0.10%
Total	3114	100.00%
Unread 07-06-2016, 13:43
It shows that we used 3 relays, when we used none. I suspect something else is being misreported as relay. 330 is row 148, in case anyone is interested.
Unread 07-06-2016, 13:46
WPILibJ doesn't currently report Relays. So relays are not shown for any Java team. That should be fixed next season however.
Unread 07-06-2016, 13:47
Flywheel Police
How did you figure that out? Did I miss the "Flipped back over to secure the win" column?
Unread 07-06-2016, 13:53
marshall's Avatar
Are you certain about this? I would think they would still show up per WPILib... I am likely wrong though.
As for tuning PID... I think we need to release some directions on how we do it... that or Omar should put his method out there. We spend maybe a couple hours tuning it and then we play with values a little here or there as needed but typically we get it right pretty quick. I'll see if I can't get a student to explain the method they use.
Unread 07-06-2016, 13:56
They don't. The encoder and counter reporting are only set when the WPILib encoder or counter classes are used. The encoders into the CAN Talons have no way currently of getting reported, as they are just methods in the CANTalon class.
So for like our robot, which is on 1885, it only shows 1 encoder, as we only had 1 hooked into the roboRIO, and the other 2 were directly into CANTalons.
Unread 07-06-2016, 13:58
marshall's Avatar
Well then... there are likely a lot more encoders not being *ahem* counted for then.
Sorry, had to do it.
Unread 07-06-2016, 13:59
Flywheel Police
