Go to Post It really is up to us to stand up for these principles so when we sell it to the general public we're not just feeding them some line because if we don't believe it, why should they? - Koko Ed [more]
Unread 07-06-2016, 18:35
Chris is me's Avatar
AKA: Pinecone
Re: What COTS parts would you like to see?
Originally Posted by Kevin Ainsworth View Post
I also want Vex steel gears in 3/8" and 1/2" hex bores, 30 teeth and smaller.
We like to make the smaller gear steel and the larger gear aluminum. Aluminum on aluminum tends to wear out prematurely. Especially for the practice robot that gets much higher wear than the comp bot.
I've never had an aluminum gear "wear out". I've broken aluminum gears, I've run aluminum gearboxes for hundreds of hours on practice robots, but I've never had a gear "wear out". I'm sure you guys are properly greasing your gearboxes and taking all of the right steps for maintenance, so I'm really curious to see what your failures look like?
