Go to Post FIRST is not about winning awards, it's about learning and advancing the human culture - crispyc [more]
  #136   Spotlight this post!
Unread 07-06-2016, 11:27
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Re: What COTS parts would you like to see?
Originally Posted by jwfoss View Post
Some offseason designs, and our limited in house capabilities leave us wishing for 1/2" hex stock with a pilot bore (aka Thunderhex minus the rounded corners).
Can you provide an example where the rounded corners make thunderhex shaft inferrior to regular hex shaft? Also thunderhex bearings alone should be enough of a reason to use thunderhex over Regular hex.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
  #137   Spotlight this post!
Unread 07-06-2016, 15:00
Michael Hill's Avatar
We had a small issue this year. We were using the cheap-o plastic Vex hubs with thunderhex shafts in the front and back (6-wheel drive, center wheel had regular hex). We had 8" pneumatic wheels on a 16:1 ratio. We noticed the thunderhex shaft was rounding out the hubs. I think it was a combination of the plastic hubs, thunderhex, and high torque at the wheel axles. We took care of the problem by switching to the aluminum hubs and regular hex and saw no more problems. I couldn't tell you which one solved the problem, whether we would have had the same issues with regular hex with the plastic bores (possible) or the thunderhex with aluminum hubs (not likely).
The problem was not strictly with the thunderhex shaft, but in that particular application, using regular hex shaft would have possibly not worn out the plastic hubs (or at least would have delayed the problem).
  #138   Spotlight this post!
Unread 07-06-2016, 15:21
Knufire Knufire is offline
I think the official VEX recommendation is using a metal hub on one side (to transmit the torque) and a plastic on the other side to support the wheel.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #139   Spotlight this post!
Unread 07-06-2016, 15:43
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We had a similar issue and cracked the plastic hubs. Some very nice people with crazy pants on Team 1296 helped us out with some aluminum replacements. Reading that note on the Vex site is important.
  #140   Spotlight this post!
Unread 07-06-2016, 16:07
I've never noticed that. Thanks for pointing it out. I knew you could get by with a single aluminum hub. I guess I misunderstood the purpose of the plastic one. In all honesty, they could just sell a plastic part with no versahub, just a mock bearing and it would work fine (and be cheaper to make).
  #141   Spotlight this post!
Unread 07-06-2016, 16:10
Basically a plastic version of this: http://www.competitionrobotparts.com...oller-end-cap/ with a 1.125" OD.
  #142   Spotlight this post!
Unread 07-06-2016, 16:30
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
http://www.andymark.com/product-p/am-1305.htm
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #143   Spotlight this post!
Unread 07-06-2016, 17:29
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
The attached gear was pocketed on each side .112, leaving a web thickness of .150.
Maybe leaving a little more meat by the gear teeth so you don't have a stress riser that can propagate to the thin web. We leave a 1/4" from the outside of the teeth to the OD of the undercut with about a 3/16" chamfer that cuts into the teeth slightly.
It looks like the broken gear has about 1/8" from the outside of the tooth to the undercut with about a 1/16" chamfer.
I also want Vex steel gears in 3/8" and 1/2" hex bores, 30 teeth and smaller.
We like to make the smaller gear steel and the larger gear aluminum. Aluminum on aluminum tends to wear out prematurely. Especially for the practice robot that gets much higher wear than the comp bot.
-4"x1.5" and 4"x2" Aluminum Wheels with 1/2" Hex Broach
-Anti-backdrive stage for VersaPlanetary
-Disc Brake set up with 1/2" Hex or "Standard" Sprocket Hole Pattern
Anti-backdrive and a disc brake add-on for 1/2" hex stock would be a great addition.
Originally Posted by mklinker View Post
I would like to see a ratcheting gear and pawl. It would be nice if the ratcheting gear had a 1/2 inch hex broached bore.
Option B would be a ratcheting gear with the standard FIRST bolt circle to attach to a hub.
Dido on the ratchet and pawl for a 1/2" hex bore. We modified McMaster ones for both our winch and climbing mechanism this year.
  #144   Spotlight this post!
Unread 07-06-2016, 17:33
AdamHeard's Avatar
Lead Mentor
I'm pretty certain we actually failed that gear on the hex as it was pocketed way too close to the shaft.
there is actually a decent amount of material under the teeth based on what we've had work in the past.
  #145   Spotlight this post!
Unread 07-06-2016, 18:21
Originally Posted by Gregor View Post
Wow! Andy's quick!
  #146   Spotlight this post!
Unread 07-06-2016, 18:35
Chris is me's Avatar
AKA: Pinecone
I've never had an aluminum gear "wear out". I've broken aluminum gears, I've run aluminum gearboxes for hundreds of hours on practice robots, but I've never had a gear "wear out". I'm sure you guys are properly greasing your gearboxes and taking all of the right steps for maintenance, so I'm really curious to see what your failures look like?
  #147   Spotlight this post!
Unread 07-06-2016, 18:58
Tal_Esh Tal_Esh is offline
FRC #3316 (D-Bug)
Team Role: CAD
Rookie Year: 2015
Tal_Esh is a jewel in the roughTal_Esh is a jewel in the roughTal_Esh is a jewel in the rough
Not sure if was mentioned before but:
-2" omni and meccanum wheels, those are quite hard to find
-custom 971's-like roborio connections board
-more bevel gears
  #148   Spotlight this post!
Unread 07-06-2016, 19:04
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
you mean this?
  #149   Spotlight this post!
Unread 07-06-2016, 19:05
This was designed by 971: http://www.wcproducts.net/catalogsea...ult/?q=spartan
  #150   Spotlight this post!
Unread 07-06-2016, 20:52
-more bevel gears
http://store.kornylak.com/SearchResults.asp?Cat=20
We rolled the RW640s in 2015 for sideways motion initially. Didn't quite work out in that application (too slick). But 118 likes to use them for other applications. Check out the transwheels as well for light loading http://store.kornylak.com/SearchResults.asp?Cat=3
