Go to Post That makes it a winning move to, well, win. - EricH [more]
Unread 03-06-2016, 00:16
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
pic: 2451 PWNAGE Planetary Drive
This is a concept I started working on last offseason. The result before build season caught up with me was a single speed drive with the wheel having an internal ring gear and pinions on the CIM motors directly driving the ring gear/wheel. The encoder is also driven by the ring gear through an idler gear.
The benefits ended up being a pretty significant gain in real estate on the chassis. This also resulted in some (albeit minor) weight savings compared to a standard single speed skid steer drive.*
I'll have gearing info, weights, etc. and more info posted once I can get the model open again. Comment any questions, etc. and I'll answer as I know it's tough to make everything out from this picture.
EDIT: The ring gear on the wheel is 72T while the pinions on the CIMs are 11T/12T. The encoder gear is 28T
Unread 03-06-2016, 00:17
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Re: pic: 2451 PWNAGE Planetary Drive
What reduction is the gearboxes at?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 03-06-2016, 00:21
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Nick can we get better pictures of the planetary setup?
R.C.
MadTown Robotics Team 1323
Unread 03-06-2016, 00:31
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
CIM motors are hidden here as well as the tread. The four screws showing are what mount the CIM to the sheet chassis.
Versa pattern cut into the plate part of the wheel to easily mount sprockets, etc.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 03-06-2016, 01:03
JohnFogarty's Avatar
JohnFogarty JohnFogarty is online now
FTC, I have returned.
AKA: @doctorfogarty
Besides weight saving and real-estate gain. Are planetary gearboxes more or less efficient than regular non-planetary gearboxes?
John Fogarty
Unread 03-06-2016, 01:08
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Generally they are less efficient. Due to this being a custom setup, to know what the efficiency of this setup would be a prototype would need to be built to find that out. A prototype would also test any issues with loads, and how stable the wheel would be.
Unread 03-06-2016, 02:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Neat idea. Your wheel looks very complex though when it looks like all you would need is an internal gear and versa key.
Have you though about how the wheel tweaking the shaft it's on could affect the Cims, if it happens at all?
Unread 03-06-2016, 11:19
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
How long until we get the two speed version?
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 03-06-2016, 12:05
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
How is the wheel manufactured? It looks like it's designed to be several layers of plates. Do you have to cut your own ring gear?
This looks like a good way to get a high reduction single stage gearbox without having the wheel's gear teeth drag into the carpet. Pretty cool!
Unread 03-06-2016, 15:54
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Currently the wheel is made of two parts. The one side of the wheel is a 1/4" this around plate with the inner hub area 1/2" thick to press the 1/2" wide needle bearing into. The other part is the round part that the tread gets riveted to. the ring gear profile would be EDM cut, with the rest of the machining work done on a mill and lathe.
I am debating making it so that the round part of the wheel is split into 3 parts, with he middle part being a steel ring gear and then aluminum parts sandwiching it in place. Some have expressed concern over the wheel being aluminum.
We'll see. I want to lock down the single speed design first, and I think I'd want to build prototype first to prove it works before moving to a two speed.
Unread 03-06-2016, 23:45
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is online now
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
<ignore this post since I'm a dumb>
Last edited by ThaddeusMaximus : 03-06-2016 at 23:46. Reason: I can't see this late at night
Unread 06-06-2016, 02:33
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Here is an update. In the album linked below is pictures of all the custom parts necessary for this design. The majority are actually relatively simple, there are really only 2 parts with any real kind of complexity. Also in the album is an updated iso view of the module and a section view to better understand what is going on.
Album here
Unread 07-06-2016, 10:52
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Is the single offset needle bearing the only thing supporting the wheel?
Unread 07-06-2016, 17:36
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
In general a planetary reduction is less efficient than a spur gear reduction. However this set up isn't really a planetary reduction and should have a frictional loss essentially a simple spur gear reduction.
The extra frictional losses occur in a planetary reduction because of the increased number of gear to gear interfaces.
In your basic spur gear reduction you have 1 gear to gear interface per stage. With a planetary set up you have 6 or 8 gear to gear interfaces as well as the friction of the pins that the planets rotate on.
This set up however does not have a sun nor really any planets, it is just the driven gear turned inside out.
Unread 07-06-2016, 22:51
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
While what you've said is accurate for these purposes in a practical setting, if I understand some of the finer points about involute gear profiles correctly, a ring gear is always slightly less efficient than a regular spur gear. Since the gear teeth of the ring gear are directed inwards, there is an increased amount of interference, which would lead to SLIGHTLY less efficiency if you use the exact same gear teeth profiles and spacing as a regular spur gear reduction.
Now, you can regain this loss in efficiency by increasing the amount of cutout in the ring gear (changing the pressure angle), or decreasing the center distance between the ring gear and pinion gear. But since both of those solutions lead to less load carrying capacity in the gear mesh, it's a trade-off. Since the OP is going with a really interesting combination of the wheel and gearbox, I would NOT risk decreasing the load carrying capacity to regain a small percentage of efficiency.
***Disclaimer***
I may be totally wrong about all of what I just said, but that's what I think is accurate.
