Go to Post This is far more then any little school extracurricular, this is a FIRST Robotics Team. - onecoolc [more]
Unread 13-05-2016, 14:27
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Re: Selecting Autonomous with TI LaunchPad?
Originally Posted by team-4480 View Post
Do you mind linking the one you used? That sounds better than using a normal potentiometer!
Rotary switches are pretty cheep and easy to use. Here's a 12 position one that would emulate what GreyingJay did: http://www.digikey.com/product-detai...1NPF-ND/370270
In one of the Launchpad example control panels I wired up an 8 position one. You can see it here to get an idea of how to do it: http://processors.wiki.ti.com/index....nalog_Wire.JPG
The red and black wire on either end of the resistor chain are +3.3V and gnd, and the one in the middle is the signal out.
Unread 08-06-2016, 02:20
Aeglos Aeglos is offline
Software Overlord
AKA: Nate- Dawg
FRC #2358 (Bearbotics)
Aeglos is an unknown quantity at this point
In response to using a TI LaunchPad-
It would be much simpler, at least in my opinion, to use a Raspberry Pi Zero, as it is so inexpensive and abundant. It can pretty easily pretend to be a joystick with as many buttons as you want, and will have a LOT more support from outside sources and forums due to its much larger user base than the TI LaunchPads.
Interesting and somewhat related side note- if I remember right from my tinkering with the Pi, the Driver Station pitches a fit if you have a joystick with more than 32 buttons/ axes/ pov's combined, so keep that in mind when constructing your interface regardless of controller. You might have to double up on microcontrollers if you want anything incredibly complex.
Unread 08-06-2016, 09:02
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Raspberry Pi runs Linux which means there is a significant boot time. If the usb cable were to come loose during a match, the last thing I want to be waiting for is the thing to boot up again.
#Python4Life
Unread 08-06-2016, 10:50
Software Overlord
AKA: Nate- Dawg
That is quite a valid point...
However, it won't be on the robot and uses only micro-b type connectors, which are latching (not locking, however), so it can withstand some abuse, but if you think it'll be roughed around too much, then definitely pick the LaunchPad.
Unread 14-06-2016, 12:37
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Sorry for the delay in responding, I sometimes disappear off Chief for a while especially right after the season is over
Here's the unit we used.
http://www.robotshop.com/ca/en/rotar...module-v1.html
We really like it. You plug it right into an analog input on the RoboRio and just read the input voltage. The resistor network (similar to ILAMtitan's second photo) is internal, and there's a nice blue LED for visual feedback too. Plus, it's cheap!
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 09-08-2016, 23:20
team-4480's Avatar
Debug? What's that?
FRC #4480
We ended up buying this exact one, but the problem is that there only seems to be a handful of values the NI Joystick Explorer sees which are .094, .1, .11, and .12. This is a problem because we really want to use all 12 parts of the switch. We are using the 3.3V rail. Is there something extra you have to do in order to make it so it reports very precise voltages? Thanks!
#Python4Life
Unread 09-08-2016, 23:41
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Originally Posted by asid61 View Post
Why not simply use a multiposition button? They look like potentiometers but have different settings you can snap to rather than an analog output.
This is how 1065 has selected auto modes for years now. 1 or 2 multi position dial and a toggle switch if needed. This year for instance we used the dial to select what we where driving over and position and then used a 3 position switch to determine if we would shoot high, low or do nothing once we got to the batter.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
