Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 08-06-2016, 08:30
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: [FRC Blog] The 2016 Season, by the Numbers 2
2363 Triple Helix should be row 861.
Unread 08-06-2016, 08:37
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
900 The Zebracorns are highly likely to be row 355.
Unread 08-06-2016, 08:48
REVving up for a new season
FRC #2848 (All-sparks)
As a Supplier we really appreciate that FIRST released this data.
There are a couple of insights that we can gain from looking at this, which help us to make some choices about our future products and their uses.
We had some interesting thoughts, specifically related to motor controllers
The number of total motor controllers reported used is probably lower than it actually is, mainly due to the number of teams that use Y cables to power their PWM motor controllers.
The types of PWM motor controllers reported likely has some errors in it, as the report out is based on library choice in code and all of them are the same (victor, talon, SPARK, etc). The total number of SPARK's used for example is considerably less than the number that are "in the wild" which means either people used different libraries in their code or a significant portion of them are used in practice bots or for testing ( I suspect a bit of both)
There are 8 teams that show having zero motor controllers.....
The average number of controllers per robot is 7.25
I am 99% sure line 1089 is 2848
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 08-06-2016, 08:58
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
I was slightly thrown off by the lack of "encoders" considering we had 6 incremental and 1 absolute encoder, but I'm 95% sure that line 592 is us.
Most of our encoders were plugged directly into the TalonSRXs.
Not a lot of 2006 Rookie year C++ teams with no pneumatics. We definitely had more than 7 Talons on our CAN interface, though I don't remember 10.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 08-06-2016, 09:52
This leads to another question about the data....when was it taken? If this was from the first time robots connected for the season it would be a lot different than if it was from a team's last match. Maybe it is an average or maximum for all of the categories.
Unread 08-06-2016, 09:57
marshall's Avatar
It was based on team number and I'm 93.2% sure it is based on the last time the team connected to the field so you are seeing the output from the final run.
I know it was based on team number and the number of controllers we have listed only happened for 1 match at NC DCMP.
Unread 08-06-2016, 10:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It's in the original [re]post - the largest for counted objects and latest for language and framework:
Originally Posted by OP
- Counted objects and TRUE/FALSE show the largest number of any given object used in any one match (i.e. if a Robot had 2 Encoders in match 1 and 3 Encoders in match 7, 3 will be reported). Language and Framework report what was used in the last recorded match.
Unread 08-06-2016, 17:12
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
I can see this happening if they only had a drive base and initialized it with the RobotDrive constructor that takes in port numbers instead of motor controller objects.
www.sharkattack744.com
Unread 08-06-2016, 22:03
I encountered more than one LabVIEW-using team that used Drive for all of their motors, not just drivebase ones.
Unread 09-06-2016, 02:37
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
There are some other explanations. At least two of the teams with no reported motor controllers are due to our framework - we don't report usage data currently, due to it not being a high priority for us compared to the other goals we could work towards. See rows 525, which is our team, and row 1951, which is another team that we know uses our software. These rows pretty much only report the language.
I could definitely understand it if something similar happened with another few projects.
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
