Go to Post We may not build the best robots but we're building better students in the long run and means much much more. - Koko Ed [more]
  #37   Spotlight this post!
Unread 08-06-2016, 11:29
Re: swerve drive with arduino mega 2560
Originally Posted by beckster1999 View Post
it's definitely the right port, the "blink" example worked
You're giving us mixed messages.
The last thing you said was basically "its not wrking". You're going to have to go into a lot more detail than that if you want us to help you make it do what you think it should be doing.
What is "it" that should be working? What do you expect it to be doing? Once you tell us that, there will be more questions about how you have "it" connected and what else you have connected to "it".
