Go to Post I believe everyone should give a modicum of repsect to each person they meet for the first time. After that it is up to them as to whether to give you a reason to increase that respect or detract from it. - Al Skierkiewicz [more]
  #38   Spotlight this post!
Unread 08-06-2016, 11:47
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: swerve drive with arduino mega 2560
Originally Posted by beckster1999 View Post
it's definitely the right port, the "blink" example worked
Ok, did you wire pin(9) of the Mega to the PWM signal of the motor controller?
Did you wire GND of the Mega to the PWM Gnd of the motor controller?
You can wire the PWM Red to +5v of the Mega, but I am pretty sure it is not required.
The Sweep servo program uses pin(9) in the sketch.
*As a debug tool, you could add code to turn on, or blink the LED on pin 13, so you would know that the program is running.
The sooner we get behind schedule, the more time we have to catch up.
