Go to Post There is nothing wrong with being great and being proud of it. - TubaMorg [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 09-06-2016, 20:55
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Python + Raspberry Pi + Kinect - Anyone Try it?
Originally Posted by lopsided98 View Post
I would recommend using libfreenect or OpenNI, both of which have Python wrappers that can be easily used with OpenCV. Personally, I would rather use one of these over the library Arhowk linked because they have a much larger user base and has been well tested.
I have personally used OpenNI on a Raspberry Pi 3 (but I didn't use Python) and it has worked well, apart from some initial issues setting it up.
You used OpenNI to use most if not all of the features of the kinect on the Pi 3?
