Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 10-06-2016, 12:55
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Re: Accessing files on the driver station laptop from the robot
Originally Posted by Alan Anderson View Post
I suppose you could run an ftp server on the Driver Station computer and have the robot program connect and transfer the file. That does mean you will have to delay the initialization of your robot program until after there is a network connection.
If you are considering Network Tables at all, why not just use a Dashboard program to read the file and publish Network Tables variables for the configuration parameters? I think the Java SmartDashboard will do that sort of thing for you.
Why don't you want to put the file on the robot itself? I can think of a couple of ways to make doing that less of a hassle, the easiest of which might be to use a simple batch file to copy the file from the Driver Station computer to the robot filesystem after you've made changes to it.
1. Is there a way I can make sure that everything that is working at home will work with field setup as well? That's my biggest concern.
2. I remember reading about a team which tried to do that and had problems (with over 100 parameters). I will search for it.
3.I didn't know it was possible, how can it be done with a batch file?
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 10-06-2016, 14:32
That's a legitimate concern. If you can ensure that you're only using the defined open port numbers, and if you have a good way of finding out the Driver Station's IP address, you should be fine. The communication library in the robot program definitely knows the address you need to talk to, because it's receiving data from it. I don't know if LabVIEW's built-in ftp function can be told to use a nonstandard port number, though.
How much run-time configuration are you trying to do?!
It might actually end up being reasonable to put a specialized web server on the roboRIO that lets you edit the configuration file in place.
The batch file just has to invoke the command-line ftp client to copy the file from wherever you keep it on the laptop to wherever you want to put it on the roboRIO. It's just a way to make things so you don't have to type the command every time you want to run it.
Unread 11-06-2016, 10:49
There was a new feature added to network tables this last year called persistence.
You can programmatically set persistence on a variable, using the Get or Update Persistence VIs (with blue floppies on the icon), or you can double-click on a variable in the dashboard to set or shift double-click to clear it.
What is persistence?
It means that the robot code will write the value to an ini-based file to keep the last known value. This is primarily for PID or pot tunings, and not as good for an auto-recipe. But if you think about it, as long as it is in network tables, it is the same on both sides. So you don't need to put the file on the robot. You can just read the file on the DB and update the variable(s) and they will show up on the robot. You can also persist them so that this is only needed when it changes.
To your original question, you can write a new program, use a command line batch file, or add code to a custom DB in order to read a file on the push of a button and send it to the robot using ftp, sftp, DAV, etc. You will need to make sure that the robot knows when to read the new file, and make sure that it is convenient to run that code.
A more manual method would be to put the file on a memory stick and insert it into the roboRIO's USB host port.
Greg McKaskle
