Go to Post This will likely fall on deaf eyes but - - JaneYoung [more]
Unread 10-06-2016, 14:32
Re: Accessing files on the driver station laptop from the robot
Originally Posted by GuyM142 View Post
1. Is there a way I can make sure that everything that is working at home will work with field setup as well? That's my biggest concern.
That's a legitimate concern. If you can ensure that you're only using the defined open port numbers, and if you have a good way of finding out the Driver Station's IP address, you should be fine. The communication library in the robot program definitely knows the address you need to talk to, because it's receiving data from it. I don't know if LabVIEW's built-in ftp function can be told to use a nonstandard port number, though.
2. I remember reading about a team which tried to do that and had problems (with over 100 parameters). I will search for it.
How much run-time configuration are you trying to do?!
It might actually end up being reasonable to put a specialized web server on the roboRIO that lets you edit the configuration file in place.
3.I didn't know it was possible, how can it be done with a batch file?
The batch file just has to invoke the command-line ftp client to copy the file from wherever you keep it on the laptop to wherever you want to put it on the roboRIO. It's just a way to make things so you don't have to type the command every time you want to run it.
Unread 11-06-2016, 10:49
There was a new feature added to network tables this last year called persistence.
You can programmatically set persistence on a variable, using the Get or Update Persistence VIs (with blue floppies on the icon), or you can double-click on a variable in the dashboard to set or shift double-click to clear it.
What is persistence?
It means that the robot code will write the value to an ini-based file to keep the last known value. This is primarily for PID or pot tunings, and not as good for an auto-recipe. But if you think about it, as long as it is in network tables, it is the same on both sides. So you don't need to put the file on the robot. You can just read the file on the DB and update the variable(s) and they will show up on the robot. You can also persist them so that this is only needed when it changes.
To your original question, you can write a new program, use a command line batch file, or add code to a custom DB in order to read a file on the push of a button and send it to the robot using ftp, sftp, DAV, etc. You will need to make sure that the robot knows when to read the new file, and make sure that it is convenient to run that code.
A more manual method would be to put the file on a memory stick and insert it into the roboRIO's USB host port.
Greg McKaskle
