Go to Post The main use of Chiefdelphi is self expression of what FIRST means to you. - Koko Ed [more]
Unread 10-06-2016, 17:40
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Pneumatic Solenoids
If we need high flow rate, we use the ones from Automation direct.
If we need compact ones we use TDKs or Festos.
If we need bulk we use SMCs (see VexPro) on a manifold.
Unread 12-06-2016, 09:33
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
One little tip, while it may be tempting to go with single (sprung) solenoids only (to save on channels) think about what happens in an e-stop/disabling.
If you use a single acting solenoid on a large arm or mechanism, then disabling can result in that solenoid shifting back into it's default position, and it's arm/mechanism flying back as well. This can pose a hazard :O
People expect a robot to stop moving when it's disabled, not all the pneumatics to retract.
We do however use single solenoids on internal mechanisms that are either low risk (eg shifters), or stay in one state for the majority of the time (eg latches).
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
