Go to Post Winning or losing on the field has nothing to do with this success. - E. Wood [more]
Unread 11-06-2016, 15:40
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Long Range Wifi
Ah, missed that. Steel should be OK, at about 54k. Thanks Blake.
750 feet through the trees: The lower the frequency, the less the trees matter. So 2.4 GHz is better than 5 GHz, 900 MHz even better. Not sure there's a good commercial solution below that. Even 440 MHz is affected, while 150 hardly at all.
No chance you could run some Ethernet, is there? drainage culverts sometimes offer a solution to cross streets...
