Go to Post I feel that the only friends I have ever had are people I know through FIRST. Being on a team gave me the sense of belonging that I thought I didn't even need. FIRST has given me a great life that I never thought I would have. - Alaina [more]
Unread 11-06-2016, 16:35
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
Originally Posted by DonRotolo View Post
Ah, missed that. Steel should be OK, at about 54k. Thanks Blake.
750 feet through the trees: The lower the frequency, the less the trees matter. So 2.4 GHz is better than 5 GHz, 900 MHz even better. Not sure there's a good commercial solution below that. Even 440 MHz is affected, while 150 hardly at all.
No chance you could run some Ethernet, is there? drainage culverts sometimes offer a solution to cross streets...
Yep, just don't ask me to be one of the poor saps who has to lug a steel pipe, plus the payload, up that 60' tower; and then hold the pipe & payload upright and aloft to attach it to the tower.
That's not a desk job. I'll create the drawings, if someone else will do the climbing .
