Go to Post [Pi day] is an irrational holiday - KenWittlief [more]
Unread 11-06-2016, 12:10
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Long Range Wifi
OK, one thing is that it boasts "automatic distance selection (ACK Timing)" so my comments about lightspeed are somewhat less relevant.
The spec for the 500 also calls for a 60 lb wind loading force at 60 MPH. Your 6061 aluminum pipe (nominal 1.25" Sch 80) yields at 24000 lbs, you have a Section Modulus of 0.291 cuin. Bending stress at the bottom of the 18' pole is (60 lb x 216 in) / .291 = 44,536 psi which is nearly double the pipe's strength - it'll bend long before 60 MPH is seen. Source (pdf)
And I still thing you're underestimating the effects of tree sway. The 3 dB beamwidth is shown as about 5 degrees, which is pretty tight (but typical for a dish, or a Yagi with comparable gain), wobble will kill your performance.
I don't disagree you need to get above the trees.
Unread 11-06-2016, 13:08
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
Don - The OP says the pipe is galvanized steel - Blake
Unread 11-06-2016, 15:40
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Long Range Wifi
Ah, missed that. Steel should be OK, at about 54k. Thanks Blake.
750 feet through the trees: The lower the frequency, the less the trees matter. So 2.4 GHz is better than 5 GHz, 900 MHz even better. Not sure there's a good commercial solution below that. Even 440 MHz is affected, while 150 hardly at all.
No chance you could run some Ethernet, is there? drainage culverts sometimes offer a solution to cross streets...
Unread 11-06-2016, 16:35
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
Yep, just don't ask me to be one of the poor saps who has to lug a steel pipe, plus the payload, up that 60' tower; and then hold the pipe & payload upright and aloft to attach it to the tower.
That's not a desk job. I'll create the drawings, if someone else will do the climbing .
Unread 12-06-2016, 11:59
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Long Range Wifi
I raised the pipe using ropes, and a jin pole, same with the dish and the top tower section comes to a point with a mast bushing in its center. So the pipe was raised, than lowered through the bushing, dish was attached and the whole assembly was raised back up. I was securely attached to the tower with my work at heights harness.
As for the 750' culverts are the way to cross streets, if used I would run the cable through 1/2" black water line to help protect it. as for the 100m ethernet limitation, a poe extender solves that
http://www.bhphotovideo.com/c/produc...x_Outdoor.html
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 13-06-2016, 09:52
Re: Long Range Wifi
Scott,
Sorry but work got in the way of responding. I have to weigh in on the pipe moving around. We have ours mounted on 4" galvanized pipe and it is only 10 feet high (roof mounted) to keep the patterns aligned. Mounting another dish on a tree flexes even more that a small pipe. With both the tower and the tree moving around and twisting, it is very likely that the dishes will pull out of alignment on a regular basis that will be nearly impossible to compensate with a moving dish.
A system to aim antennas real time, requires some method to determine the direction of the move and magnitude. I have seen this done with a system that "wobbles" the device so that a feedback mechanism can detect both direction and magnitude. You would not want to due that with a dish for mechanical stress. You could move the feed horn which is a much smaller mass but it may not give you the range needed.
As to trees in the fresnel zone, if they were simply into the zone and not obstructing it, the path loss would seem to overcome the phase rotation introduced by the leaves. However, I think the trees are likely obstructing the path and you have significant path loss that this dish pair cannot overcome. Just running a quick path loss calc it looks like you could easily have 80 dB loss without the trees with this dish pair. I would bet that the tress introduce a variable or between 20 and 40 dB additional loss. That eats all of your available margin. The only way to overcome path loss is to increase transmit power, receiver gain or antenna gain(size). With the antennas you are using, none of those are possible. Even going to the 620 antenna only gets you another 2dBi. I think you have to pick up another 10-20dB of gain.
For my money, a larger antenna mounted on the tower and not a pipe is preferred. I can speak to leaves being a significant attenuator at 450 MHz. Many digital broadcast stations are finding that antenna placement for our viewers need to be away from trees. Many folks who had no problem with reception of our high VHF station in the past, have issues on our Ch47 (660MHz) UHF digital station. When it rains, data loss is significant to the point of no reception at all.
