Go to Post In fact, our robot YOLOs so hard it does drive-bys on the refs. - TrevorKN [more]
Unread 06-11-2016, 05:49 PM
streamlined streamlined is offline
FRC #1334
streamlined is an unknown quantity at this point
Chain Spacing?
How do teams determine how far apart to place two sprockets to ensure correct chain tension? This year, our robot's biggest issue was the drivetrain, and specifically, its chain.
As an example, I tried using a calculator, and I input 18 teeth for the sizes of both my driven and drive sprocket, and selected 116 links, and the centre-to-centre distance given was 12.25". Upon making a test piece with the same sprocket sizes to test this number, the chain had significantly less links than 116, and was still very loose. How do I figure out how far apart to place the sprockets for proper tension? Do you use calculators? Do you have a rule of thumb? Did you just eyeball it, or get lucky? Please let me know!
Unread 06-11-2016, 05:56 PM
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Chain Spacing?
First off, for a long chain run (12.25" certainly qualifies), it's a good idea to have adjustable tensioning for the chain, both in case you don't get it quite tight the first time around and to account for the chain stretching as it's used.
That said, we use a calculator. I typically use this one, but it doesn't really matter which one you use. Make sure you're inputting the correct chain pitch. #25 is 0.25" pitch and #35 chain is 0.375" pitch.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 06-11-2016, 06:11 PM
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Re: Chain Spacing?
Sprocket Center Distance and Chain length Calculators
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 06-11-2016, 06:29 PM
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Chain Spacing?
The calculator you used appears to be correct, assuming #25 chain and .25" pitch. With same size sprockets, ((2*C-C)/pitch)+sprocket teeth = #of links. This is just top length of chain + bottom length of chain + chain wrapped on first sprocket + chain wrapped on other sprocket. The top and bottom lengths = the center-to-center distance, so divide that by pitch to get number of links. The number of links wrapped on 2 halves of equal sprockets is the number of teeth on the sprocket. For your calculation, ((2*12.25)/.25)+18=116. In theory the chain would've been fine. There was some other problem in your setup.
As a rule of thumb, simply make the C-C distance a multiple of chain pitch and you will end up with a nice, even number of links. This is assuming same size sprockets with an even number of teeth, which is what we always use on drivetrains. Every #25 sprocket sold by Vexpro has an even number of teeth anyways. Only when sprocket sizes are different would I turn to the calculator.
As Bazel A suggested, adjustable tensioning is the proper way to make sure the chain continues working even as it stretches. But since FRC robots don't have to run for all that long, some teams forgo adjustable tensioning with no problems. They just use exact C-C distance, or add .018"-.02" to the C-C distance to account for the chain stretch. Done properly, this setup could last your robot through a full season.
Unread 06-11-2016, 07:45 PM
FRC #1334
Re: Chain Spacing?
I don't mind using a tensioner to adjust for chain stretch. We've tried using calculators to no avail, the chain is still loose enough to be pulled off by hand. The 12.25" chain run was actually calculated using the exact calculator you linked me to. I am using brand-new unused #25 chain. Are there any other variables that could influence the tension of the chain? What do you view as proper tension?
Unread 06-11-2016, 08:11 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Chain Spacing?
This may not be your issue, but note that if "116 links" on the chain calculator for two 18 tooth sprockets gave you a C-C of 12.25", the "116" meant "half links", equivalent to "116 times the chain pitch," or 29" long if broken and stretched out straight; a bit under 14.5" if the loop were stretched with no sprockets inside, which makes sense if stretched around some sprockets 12.25" apart. Perhaps you thought it meant 116 "whole links", which would be twice as long?
Unread 06-11-2016, 11:43 PM
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: Chain Spacing?
What are your tolerance's for the part your used the chain on? That might contribute to the mistake. Also what size chain did you use? I know it is not uncommon for someone to think #35 chain has a .35" pitch instead of .375" which is the real pitch.
*Edit* just saw that it was #25 chain. Add .018" to each cenet to center distance, but only do center to center if your machines can hold tolerance's. Otherwise use the versa system with tensioners. I am open to work one on one with anyone needing help with C to C chain designing, message me if you are interested.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 06-12-2016, 12:45 AM
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Re: Chain Spacing?
Something else of note, chain stretches considerably. What WAS a snug, taught chain during build, will be sad, loose chain after 2 events.
1076 uses adjustable chain tensioning on all chain that transfers considerable torque.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2016: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
