Go to Post I always felt people get too caught up in the robot and don't see what really makes the teams function so well is the organization itself. - Koko Ed [more]
Unread 12-06-2016, 11:55
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Lightbulb What FRC Calculators do you want
Note: all abbreviation meanings can be found below.
I've developed an FRC calculator that can so far, take (Wheel Size)+(RPM)+(2 stage gearing)=(FPS). And a Linear Actuator Calculator that takes the (RPM)+(2 stag gearing)+(Thread Pitch)+(TPI)+(Actuator's overall travel distance)=(DPS) and (TTC).
So now on to my real question, what kind of calculator would you like to see implemented or have? (examples would be, Center to center gear/belt calculator,etc.) Thank you for time.
Abbreviations:
RPM = Revolutions Per Second
FPS = Feet Per Second
DPS= Distance Per Second
TPI = Threads Per Inch
TTC= Time To Complete
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 12-06-2016, 19:27
Moskowapplepi's Avatar
Moskowapplepi Moskowapplepi is offline
FRC #2067
Moskowapplepi is an unknown quantity at this point
Re: What FRC Calculators do you want
A district points calculator
Unread 12-06-2016, 19:31
ATannahill ATannahill is offline
AKA: Alex Tannahill
Are you talking about a what if calculator? The FIRST and TBA ones update nearly live. What capability do you feel they lack?
- Arizona North
Unread 12-06-2016, 19:47
FRC #2067
Yes a what if calculator. The capability they both lack is input from the user to see what would happen with a certain ranking, award, playoff performance/selection.
Unread 12-06-2016, 20:01
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
I would try and develop calculators that aren't already in the JVN Calculator.
As for what I would find useful:
Might be helpful to have a calculator that took the path length of a belt/chain run, the C/C distance of this belt/chain run, and give you the lateral distance off the centerline where a tensioner would need to be placed to properly tension the belt/chain run. (I have no idea if I explained that well.)
Also might be nice to have something that calculates the amount and placement of counterweight and/or counter force on some sort of arm so that it is balanced.
Unread 12-06-2016, 21:30
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I'd be over the moon for any calculator that uses metric nativley.
In fact, last I checked, JVN's calculator did a lot in metric, with conversions on the inputs and outputs. It's also funny to see imperial calculators for metric pitched belts...
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 13-06-2016, 10:42
Knufire Knufire is online now
A time-to-distance drivetrain calculator with an experimentally determined friction model of the robot that also factors in voltage drop of the battery.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 13-06-2016, 11:06
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
I'd be understating myself if I said that was a tall order.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
What outputs would you like, or how would you like to us this tool?
Unread 13-06-2016, 11:16
AdamHeard's Avatar
Lead Mentor
It's really not that bad actually, and I believe a few versions of that (or darn near it) have been posted over the years.
Unread 13-06-2016, 11:24
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I have seen/heard of a few versions.
I think with the PDB now reporting channel currents, and even more accurate version could be correlated with a little bit of testing. That being said, If the tool is meant to be a predictor, then very little test information would be available at the time.
Unread 13-06-2016, 11:35
Chris is me's Avatar
AKA: Pinecone
I've seen it, but not with voltage drop factored in before. This would be the Holy Grail of drivetrain calculators, I think.
Unread 13-06-2016, 11:46
Data Nerd
FRC #0079
https://www.chiefdelphi.com/forums/s...d.php?t=119442
Unread 14-06-2016, 00:30
Active Alumni
Unfortunately, my current level of electrical knowledge is no where near what i would need to now about battery consumption so I will most likely not add that in until way later but I'm still open to other suggestions
(sorry for the bad pun )
Unread 15-06-2016, 20:16
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff is a jewel in the roughs-neff is a jewel in the roughs-neff is a jewel in the roughs-neff is a jewel in the rough
There was an Excel-based extension to JVN's calculator that 841 pulled down from CD & used extensively in design this year (though we have not verified the results).
I can't find it right now though
Probably using the wrong search terms.
