Go to Post Darn elite teams and their mentor-built caves. - Brian Maher [more]
  #31   Spotlight this post!
Unread 24-12-2014, 15:35
ttldomination's Avatar
Sunny
Re: pic: REV Robotics building system
I saw the extrusions are available on AM, and most of it looks decent.
I was wondering, in the images and documents that show the V-Bearing in use, the bearings are attached to a base plate of some sort. Are there plans to provide that base plate + V-Bearings as a kit?
- Sunny G.
1648: 2013-2014
5283: 2015
  #32   Spotlight this post!
Unread 24-12-2014, 20:36
REVving up for a new season
FRC #2848 (All-sparks)
- Sunny G.
Yes, There will be a kit. The kit would include 2 bearings, the eccentric + concentric bushings, the mounting plate, and the 2 nuts/bolts you need.
The plates are in transit now from the machine shop, and will be available before kickoff. A late change was made to allow teams to use normal 3/8 bearings with the same plates and bushings to build a 254 style lift using regular 1x2 tubing as another option.
We are going to be posting a whole bunch of applications to www.revrobotics.com over the next couple days.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
  #33   Spotlight this post!
Unread 24-12-2014, 21:14
Sunny
Sweet, looking forward to it.
- Sunny G.
1648: 2013-2014
5283: 2015
  #34   Spotlight this post!
Unread 04-01-2015, 13:08
Now that we know what the game is, I thought I would highlight the linear motion capabilities of the REV extrusion.
We have posted some new guides to our website on using the building system, and plan on releasing some full plans for some basic elevators (not complete plans) in the next day or so.
Check out our guides here. http://www.revrobotics.com/building-system-overview/
All of the parts that are out of stock right now for the system, will be in stock early next week.
  #35   Spotlight this post!
Unread 22-01-2015, 12:42
REV extrusion is now in stock at AndyMark. http://www.andymark.com/product-p/am-2901.htm
all the other parts will be coming back in stock over the next few days.
  #36   Spotlight this post!
Unread 22-01-2015, 13:27
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
The bearings show an ETA of 1/30 - is that still correct?
  #37   Spotlight this post!
Unread 22-01-2015, 13:52
I think that is about right on the bearings, we shipped all of our inventory to AM last week, but it was sold out in less than an hour. We are waiting on fulfillment from our supplier.
In the meanwhile the bearing is a standard size (RM2ZZ) and there are lots of places you can get them now (if you don't mind paying a bit more for them)
VBX sells the most comparable to quality version http://www.vxb.com/page/bearings/PRO...arings/Kit8407
There are some lower cost options out there that are the right size, but I have not tested them to know the quality. Quality significantly varies bearing to bearing, so be warned. My gut says they will work just fine for FRC, but I can't guarantee it.
Here is one of those sources.
http://www.thebigbearingstore.com/se...-ZZ-VW2/Detail
Both bushings will be in stock in the next day or so.
  #38   Spotlight this post!
Unread 14-06-2016, 20:11
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Hey Gang,
What is the load bearing capability of the 1" extrusions? That is, how does it compare with 1" square 1/8" square 6061 aluminum tube? If I've done the math correctly, the Rev extrusion seems to be lighter than the 1" square aluminum tubing. So, I'm trying to determine if it's a better option than welding the 1" tube for a frame.
TIA,
Mike
  #39   Spotlight this post!
Unread 15-06-2016, 00:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Loading in what direction?
For most deflection and torsional loading (including buckling), the stiffness depends on the moment of inertia of the cross section, which, for a given amount of material, increases as the square of the distance from the center. For a given amount of material and diameter, a hollow round tube will have the greatest moment of inertia (be strongest), with a hollow square tube being a little bit behind. Shapes like I-beams and rectangular tubes are designed to have a larger moment of inertia in one dimension (the longer dimension) than another to accommodate a larger load in that direction.
For tension loading, I understand that shape makes less difference unless your material forms fibers.
Shapes like the REV and 80/20 extrusion require more weight for the same strength; their purpose is in easy fabrication using tee nuts and similar fasteners.
  #40   Spotlight this post!
Unread 15-06-2016, 01:22
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Can you be a little more clear? Which has less deflection, the tubing or the extrusion?
  #41   Spotlight this post!
Unread 15-06-2016, 01:41
Just to be a total annoyance (and to give you a taste of real engineering):
What's the load case, the size, and the wall thickness? Oh, and how is it supported? You see, the answer depends on knowing those... OK, OK, I'll go a little easier than that.
What he's saying is, essentially, more material at the outside of a piece of material will resist deflection better, given the same mass and size. BUT, extrusion may be tailored to resist deflection better in one direction. (I-beam being one example--it'll bend better if you're trying to bend it in the direction of the open sides than if you try to bend it towards the flanges.)
Moment of inertia (and in this case, that's MASS moment of inertia) is something you'll tend to hit somewhere around 2nd-year engineering coursework, possibly a hair sooner. It's not that hard in concept; the simple definition works out to how much torque it takes to rotate an object about a given axis. Now, the actual application of that definition, and the formulas to help determine it, are where that gets fun, as the shape of the object in question plays a role (which is why that was brought up in the explanation). If you're interested in running through some of the math, let someone know; that can be arranged...
  #42   Spotlight this post!
Unread 15-06-2016, 08:14
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
That is, tubing is the stiffest shape there is for loads which may be required in every direction sideways to the length.
  #43   Spotlight this post!
Unread 15-06-2016, 08:49
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
I'm pretty sure the discussion is about AREA moment of inertia (units of [length]^4). Though your description of mass moment of inertia (units of [mass]x[length]^2) is related to rotational inertia, it's not germane to this discussion.
Regarding OP's question:
We found the extrusion to be heavier than the thin-walled tubing we've previously used for frame elements. Are you possibly referencing 1/8" wall square tubing? If so, I'm fairly confident the tubing is stiffer in bending and torsion than the Rev Extrusion. As far as axial stiffness (along the length) it's going to be proportional to the cross sectional area, which is proportional to the weight/unit length for the same material.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
  #44   Spotlight this post!
Unread 15-06-2016, 09:50
FYI the for REV extrusion are as follows.
Cross Sectional Area: 0.38133 in^2
Moment of Inertia X: 0.03394 in^4
Moment of Inertia Y: 0.03394 in^4
Yield Strength: 21000 Lbs./ sq. in (psi)
Modulus of Elasticity: 10007000 Lbs./ sq. in (psi)
The debate as to which is stronger really does depend on your loading conditions and use case. If you are talking in the context of FRC style robots, I highly doubt you will see a notable difference in strength per piece (as small deflections) don't really effect much in this case.
Where you will see the difference is in how you join them. A welded 1x1 tube is going to be better than a piece of extrusion with nuts and gussets, but there again it depends on your use case and for FRC scale applications you can't go wrong with either.
Last edited by Greg Needel : 15-06-2016 at 11:33. Reason: fixed cross sectional area units....
  #45   Spotlight this post!
Unread 15-06-2016, 10:06
MechEng83's Avatar
AKA: Mr. Cool
Cross Sectional Area: 0.38133 in^2 (FTFY)
Thanks Greg. Always good to hear specs from the figurative horse's mouth.
I'll file this info away for comparison discussions with my team.
Red Alert Robotics
