Equipment list
Hey everybody!
I am making a list of everything that we should buy for next year for the electrical team and I was wondering if you could share with me an example of your own for equipment list Thanks! Stav Head of electronics OnyxTronix #2231 |
Re: Equipment list
Get this terminal crimper for the battery cables:
https://www.amazon.com/Crimper-Crimp...+crimper&psc=1 You won't believe how well this thing works for $29 (although I don't know how much it will cost in Israel). We tried the yellow hydraulic crimper you'll see sold under various names. ***avoid this one like the plague*** After 10 terminals it will leak a most foul smelling oil everywhere. We prefer to make our own PWM and sensor cables. The commercially available cables may have improved over the past few years, but we like having the flexibility to make exactly what we need. Here are the part numbers for what we use (all Molex numbers): Female contacts: 16-02-1114 Male contacts: 16-02-0114 3-contact housings: 50-57-9003 4-contact housings: 50-57-9004 5-contact housings: 50-57-9005 Crimper: 64016-0201 (sorry, $130!) Use good 22AWG wire with thin insulation and at least 19 strand count. The 7 strand wire used in many PWM cables breaks after a few flex cycles. Last edited by electroken : 06-15-2016 at 07:40 AM. |
Re: Equipment list
Anderson Powerpoles for motors and controllers.
Crimper for the powerpoles. Cable Management supplies like zip tie mounts, stick on mounts, zip ties Soldering iron and heat gun combo and solder. Don't forget about heat shrink. Use it to protect your connection and/or to color code wires, etc. |
Re: Equipment list
You can get other colors of Power pole connectors at Powerwerx. We used them for canbus, sensors, just about everything. And you can key connections in different directions so they literally cannot be plugged in to the wrong thing. Powerwerx also sells the crimper, and have 15A, 30A, and 45A crimps. Great for offseason projects and test beds too.
Re: Equipment list
Wire. Flexible type (high strand count) in several sizes (10 to 18 at least)
Wire strippers. The 'kinematic' type (like these ). Contacts and housings (depends on connections you use. Recommend Anderson Powerpoles) Screwdrivers (very small blade-type to mid-size philips) Pliers (including needle-nose) Wire cutters A soldering iron (25 W) and solder Electrical tape of good quality (black) Heat-shrink tubing assortment Crimp-type insulated spade, ring and 1/4" terminals in various sizes, and a RATTCHETING crimper for them. Wire ties: 1/8" x 4-5", 3/16" x 12", 1/4" x 12". Hundreds of them. Some spiral-type wire covering Marking tape: colored tape or label-maker tape to mark ALL wires at both ends. That's what i can think of at the moment |
Re: Equipment list
Re: Equipment list
If the connection is one that is unplugged frequently we have seen that the "locking" of the two plastic housings degrades. To help mediate the risk we simply place a zip tie around the connection. TL;DR - we are huge fans of the Powerpoles for competition robots, practice robots, R&D projects, and beyond. |
#8
Re: Equipment list
1) Use the proper size wire in the proper size terminal 2) Strip the wire the appropriate amount and make sure that your wire cut is pretty straight and you don't have extra nicks in the cable. Too much exposed copper can lead to bends and breaks, nicks can lead to breaks, and not enough copper can lead to power connections 3) Do a pull test after EVERY crimp. Though the Anderson crimper really works pretty well where if you squeeze it down to the point where it releases on it's own you're probably fine 4) make sure the metal tab is fully inserted with the tab going over the metal tongue in the plastic housing. If it doesnt click or can be pulled out easily after inserting the crimp into the housing you've probably done something wrong. 5) Perhaps most importantly, have a proper strain relief/bend radius on your wires. Ideally you wires should be zip tied to structure somewhere shortly after it's connection so that any strain on the wire is taken by the zip tie - not the connector. 6) I like to have a consistent way that the andersons are connected. Personally I've gone with "red on the right" by looking at the connectors from what I consider top down. (I consider the metal tongue to be the bottom of the connector). This way the connectors should be consistent across everything. If you're having problems with the andersons disconnecting - you can get the 2 pronged tab that holds them together. |
#9
Re: Equipment list
Ha! I decided to standardize "Red On Right" for my team too! I drew a handy illustration on the shop chalkboard to declare it to all.
#10
Re: Equipment list
If you want to use your own sensors/cables (we used in-wall style four-conductor alarm wire for encoders) I'd reccomend investing in a "PWM" or Dupont connector set and crimper. We got a set like this.
#11
Re: Equipment list
Some of the "nice to haves" but border on "necessary" to me:
Once you get that, and if money is available:
Last edited by ahartnet : 06-15-2016 at 05:46 PM. Reason: fixed a typo, and removed a bias that unnecessarily drives up the cost of a tool |
#12
Re: Equipment list
I would also suggest looking into stocking some basic sensors ahead of time as well.
Multi-turn pots Limit Switches 1/4 inch shaft encoders If your team also covers the vision processing, whatever camera and boards you plan to use. |
#13
Re: Equipment list
+1. Was so busy thinking about the tools for electrical I didn't think to include sensors. limit switches are something easy for any FRC participants to add to make their robots more robust/controllable; potentiometers, gyros, and encoders really aren't hard either nowadays with all the WPIlibs.
