Go to Post Some companies cut costs (and cut corners to do so). Some work hard to build loyal customers. Which would you rather purchase from? - sanddrag [more]
Unread 15-06-2016, 23:30
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
I have a lot of experience with XT connectors as they are connector of choice for personal projects. I used to use Deans connectors but they are much easier to melt when soldering and occasionally the spring tabs would bend ruining the connector. XT connectors are also easier to solder than Deans because of the cups on the terminals.
Personally I would rather solder connectors than crimp as it requires less specialized equipment and lessens the chance of a intermittent or high resistance connection which can be very difficult to diagnose.
Another advantage of RC connectors is that they are gendered(male and female) unlike Anderson connectors. This prevents a user from plugging a battery into another battery or the motor side of a speed controller into a power source and destroying it.
I've never been a fan of JST connectors, they are very low amperage and only really useful for something like LEDs. They are also difficult to grip and pull apart without tugging on the wire.
2016: FRC 865 Mentor
