Go to Post All I can say is - we are such geeks! - Raul [more]
Unread 16-06-2016, 23:10
Mikey Richards's Avatar
Mikey Richards Mikey Richards is offline
FRC #3812 (Bits and Bots)
Rookie Year: 2015
Mikey Richards is an unknown quantity at this point
Disable Robot in Code
Our team is trying to add a button to our joystick that disables the robot. Right now we are using java's System.exit(0), but this also loses the robot code. Is there a way to disable the robot, but not lose robot code.
Unread 16-06-2016, 23:23
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Disable Robot in Code
Pseudo(ish)code:
boolean disabled = false;
if (button pressed)
disabled  = !disabled;
if (disabled)
all motors set at 0
else
normal code executes
This needs to go in the main control loop.
Unread 17-06-2016, 08:15
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
If you're using a command based project the above code may be difficult to integrate.
Instead you could just stop the scheduler from running (preventing your commands from executing) by calling Scheduler.getInstance().disable();
When you want to enable the scheduler again call Scheduler.getInstance().enable();
Note that depending on how you output values to your motor controllers, they could latch on the last command they received before you pressed the button. Test your code out with the robot on blocks and with a mechanism that can't stall out and break itself before you use it for anything safety related.
Note that the robot is still "enabled" so it's possible for things to move of they are commanded to do so (if you have code that sets outputs that's not run within a command).
Sent from my LGLS751 using Tapatalk
http://team2168.org
Unread 17-06-2016, 09:44
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Put something on the DS that sends a [enter] keyboard command when the button is pressed? We tested this at one time on our teeshirt cannon. We haven't actually implemented it yet though.
Unread 17-06-2016, 13:23
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Edit: DriverStation has a function called InDisabled(boolean)
Try calling that with true; it might work.
You can override isDisabled() in your robot class like this:
public boolean isDisabled() {
    return super.isDisabled() || myDisableFlag;
This should work whether you extend RobotBase or IterativeRobot
Two things:
- The Driver Station won't recognize that you are disabled when you set the flag
- You'll need to make sure to clear the flag yourself when you want to enable again
