Go to Post 15 thread derailment points - EmileH [more]
Unread 16-06-2016, 09:35
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Electrical connectors on control system items
Originally Posted by Christopher149 View Post
The screw connector for powering the roboRIO (and previously cRIO). I don't know if we were using it wrong, but especially on the cRIO, the wires would too frequently come out or be loose.
I like to call screw terminals like these the best bad connector you will use. They're relativley versitile, flexible, easy-ish to use with medium pincounts. However they will never be better than a more specilised conector.
On to the OP's question:
I'm not interested in any new connections unless there are some very good reasons. Inventory management is a PITA, and it's much easier to maintain an inventory of 100x of one conector, vs 25x of 4 different ones. For this reason I'm willing to make reasonable comprimises on all the advantages/disadvantages you mentioned, for connectors already in common use.
This is all the more important if your intended market is ALL of FRC, ie not just the average to powerhouse teams that already have things like this worked out. Having helped many rookie and low-resource teams wire up robots, trust me when I say there is enough in the combination of Wago, Weildermuller, [3-pin only] PWM etc already.
It's a little different if your targeting just the medium-powerhouse teams. As other others have already mentioned Powerpoles, custom .1in (ie other than 3pin PWM), rings and spades, IDC, USB and ethernet etc all have some really good use cases.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 16-06-2016, 14:58
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Originally Posted by Knufire View Post
I really like the connectors on the US Digital S4/E4 series encoders. Browsing around on their website, it looks like it's a 1.25mm pitch Molex PicoBlade connector.
https://youtu.be/0bRyezC_P0M?t=141
The big thing I enjoy about them are the friction locks, they feel much more secure than standard 0.1 header connectors. I wouldn't mind a bigger pitch than 1.25mm though for FRC use though.
Huh, I've always hated those. The attached wires were always a pain and usually messy, plus unplugging them didn't always go well.
We started using some custom .1in connectors this year for different sensors, like a 5-pin one for Grayhill encoders and some 2-pin ones. Those worked well when done correctly, but our quality control wasn't great, and a few connectors made it onto the robot that might have given us some intermittent signals. We're learning, though, and I think we'll go back to them and use more next year.
We also had some trouble with several Weidmuller connectors. No matter how many times we tried with different wires that were the correct gauge and stripped the correct length, a few connectors just wouldn't work. Others were perfect and lasted all season. We picked up some ferrules to try to address that next year.
The 3-pin connectors are decent. We wound up taping and zip-tying a lot together, though, so we might pick up some VEX EDR connector clips. I'm a bit disappointed that the RoboRIO has male pins. We had one of those connectors come loose despite us using 3D printed cable management/spacing inserts. Other than a giant 10-connector female-to-female converter that plugs into all of them and reinforces everything, I don't really know how to address that.
I haven't personally used the XT or Deans connectors, but, given the option, I would stick with Powerpoles. They can clip together to make large plugs, they're easy to lock together, and we have tons of them stockpiled.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 16-06-2016, 16:18
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Originally Posted by Greg Needel View Post
[*]Anderson Powerpole - main battery connector & commonly wire to wire connections - medium price, good quick release, hard to crimp without special tool
Deans connectors - https://www.amazon.com/dp/B00S7G4A14/ instead of power poles or wagos
Deans Connectors: Hate these things. A'lot of RC's use them, but I've always had issues with them.
Anderson Power Poles: Go with these. I absolutely love these. FTC switched over to a new control system that uses these in pretty much everything, so my teams have a large stockpile of them. After having the right tool, they are easy to work with! My teams love the fact that you can create large blocks of connections, which has already been said in this thread. Allows us to remove parts easily to work on parts of the robot or to switch out. Some of the electrical students on my FRC team saw them this past year, and want to make the switch to them next season.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 17-06-2016, 00:06
Molex connectors (http://www.molex.com/webdocs/datashe..._HOUSINGS.pdf). They are polarized and latch pretty well. We've gotten pretty good at crimping them.
Unread 17-06-2016, 07:26
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Looks like you got that close parentheses in your url. Here's a working link.
Unread 17-06-2016, 11:45
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
I think it would be nice to see a pair of two or a single four pin connectors on the CAN cables for the Tallon SRX's. That way if you pre-terminate spare controllers it could be changed out with mounting the new one and plugging it in.
http://www.digikey.com/product-detai...2083-ND/141479
http://www.digikey.com/product-detai...2019-ND/141249
Unread 17-06-2016, 12:14
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
We do exactly this with the 2-pin Latching Polarized (LP) 0.1" connectors from Hansen Hobbies (1). Put male on one pair and female on the other pair and daisy chaining is a cinch. The connectors have a plastic spring latch so won't come apart under vibration and are polarized so they can't be plugged in backwards. We put stub connections (short wire and connector) on other devices like the roboRio and CTRE products so we only need to deal once with insertion/removal into those connectors.
1: http://www.hansenhobbies.com/product...nlpconnectors/
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 17-06-2016, 12:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
This, this, this.
Also, while many teams have Power Poles as an internal standard (3946 among them), I am not aware of any standard FRC parts which require/strongly encourage teams to use them. They do meet all the requirements (current capacity, well insulated, vibration resistant) and many "desirements) (modular, customizable, polarizable). They also have a great customer base outside of FRC (ham radio and R/C modeling, and probably others).
Unread 17-06-2016, 12:25
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
My biggest concern is non-latching connectors. In a high-vibration and relatively high shock environment like a FRC robot it is mal-practice to use non-latching non-polarized connectors. They don't have to be fancy or super expensive but really should have a latch.
And like other posters, I prefer screw-type terminals.
Unread 17-06-2016, 12:58
WPILib Developer
While power poles aren't natively latching, we use the little orange clips that powerwerx sells. They're easy to install and have been very robust for us. My only other complaint with power poles is that the crimp doesn't grab the insulation (only the wire) so pull-out can be an issue. We make sure to tug-test every crimp and prefer the 45a contacts for all but the smallest wires as they seem to grab the wire better.
Unread 17-06-2016, 13:02
Chris is me's Avatar
AKA: Pinecone
228 uses Deans connectors and I think they're fine. You have to solder the wire to them, sure, but other than that they are a robust connector that clips together securely and nicely. Soldering and shrink tubing the wires to each lead helps them hold securely. Never had an issue with them failing a pull test.
If you go all in with the tooling, Anderson connectors are very robust. I don't particularly care for the whole snapping multiple connectors into one big block thing. Spade connectors are okay I guess.
Almost any connector, latching or otherwise, can be made more secure with heat shrink tubing to hold it together. It's difficult to accidentally pull apart a spade connector if the tubing constrains it geometrically.
Unread 17-06-2016, 13:48
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
+1. We've been using molex connectors ever since we started using the Spartan Board in 2015. The latching is very nice
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 17-06-2016, 13:53
Data Nerd
FRC #0079
We did the same on our can bus this year. Worked wonderfully.
Unread 17-06-2016, 18:36
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
We use wire ties to make sure the power poles stay together. I always forget to buy the little orange clips.
Unread 18-06-2016, 23:56
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Tiny zip ties work really well for securing PowerPoles too, that's how I've always done them.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
