Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
  #121   Spotlight this post!
Unread 16-06-2016, 23:57
Re: FRC971 Spartan Robotics 2016 Release Video
Originally Posted by ranlevinstein View Post
I managed to solve for u assuming Q is symmetric and the trajectory is feasible. I got:
u = (B^T *Q*B)^-1 * (r(n+1)^T - r(n)^T * A^T)*Q*B
Is that correct?
def TwoStateFeedForwards(B, Q):
  """Computes the feed forwards constant for a 2 state controller.
  This will take the form U = Kff * (R(n + 1) - A * R(n)), where Kff is the
  feed-forwards constant.  It is important that Kff is *only* computed off
  the goal and not the feed back terms.
  Args:
    B: numpy.Matrix[num_states, num_inputs] The B matrix.
    Q: numpy.Matrix[num_states, num_states] The Q (cost) matrix.
  Returns:
    numpy.Matrix[num_inputs, num_states]
  # We want to find the optimal U such that we minimize the tracking cost.
  # This means that we want to minimize
  #   (B * U - (R(n+1) - A R(n)))^T * Q * (B * U - (R(n+1) - A R(n)))
  # TODO(austin): This doesn't take into account the cost of U
  return numpy.linalg.inv(B.T * Q * B) * B.T * Q.T
  #122   Spotlight this post!
Unread 17-06-2016, 03:48
kylestach1678's Avatar
kylestach1678 kylestach1678 is online now
AKA: Kyle Stachowicz
FRC #1678 (Citrus Circuits)
Rookie Year: 2015
kylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to beholdkylestach1678 is a splendid one to behold
Originally Posted by AustinSchuh View Post
The equation to minimize is:
This cost function is just the state error part of LQR, correct?
I noticed that this solution ends up evaluating to the (pseudo)inverse of B when Q is a constant multiple of the identity matrix, which is the solution to R(n+1)=A*R(n)+B*u when u=Kff*(R(n+1)-A*R(n)). What is the reasoning behind using the LQR weighted solution instead of the simpler version?
  #123   Spotlight this post!
Unread 17-06-2016, 20:17
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
You set your wheel velocity to 640 in your shooter code. I can't figure out what unit of measure this 640 is calculated in; RPM would be too slow while RPS would be too fast. What unit do you use, and is it related to your model based calculation of everything? (Do you have any tips for starting to learn how to run everything using models?)
  #124   Spotlight this post!
Unread 17-06-2016, 20:49
Rookie Year: 2015
Radians per second, I would assume. Everything in standard units . Using radians makes the derivation of the models simpler, especially when the rotation eventually gets transformed into linear motion, and it is nice to be consistent across the board.
  #125   Spotlight this post!
Unread 27-06-2016, 22:56
I modeled it as you said and I got that:
acceleration = a * velocity + b * (voltage error) + b * u, where a and b are constants.
I am a bit confused about why this is true because the voltage error is in volts and u is volts/seconds so you are adding numbers with different units.
Nice catch. Maybe I wasn't clear, but U changed units from volts/sec to volts, and the integrator on the output of the plant disappeared.
I am still having some problems with understanding it, if the system is behaving just like it should then the integral of the voltage error will be zero and then there is just a PI controller. In my mind it makes a lot more sense to have:
u = constant * position error + constant * velocity error + constant * integral of voltage error
Maybe there is a problem with velocity error part here but I still don't understand how there won't be an integral windup when you have integral of position error in your controller.
What am I missing?
I *think* you are off by an integrator again.
u = Kp * x + Kv * v + voltage_error
So, if torque_error = 0 (the model is behaving as expected), then you don't add anything. Ask again if I read too fast.
Also I saw you are using moment of inertia of what being spun in your model, What units is it and how can I find it?
kg * m^2
I was wondering about how the delta-u controller works when the u command get's higher than 12 volts, because then you can't control the rate of change of the voltage anymore.
Thank you so much! Your answers helped my team and me a lot!
You have the same problem with a normal controller. The nonlinear assumption breaks down there too. We just cap the accumulator to +- 12.
To solve that all correctly, you'll want to use a Model Predictive Controller. They are able to actually take into account saturation correctly. Unfortunately, they aren't easy to work with. We haven't deployed one yet to our robot. (Go read up on them a bit. They are super cool That was either one of, or my favorite class at college.)
It's been another busy week. Sorry for taking so long. I started a reply a week ago and couldn't find time to finish it.
  #126   Spotlight this post!
Unread 27-06-2016, 23:00
Yes. Since it doesn't have the U part of the LQR controller, it isn't provably stable, and I've seen ones which aren't...
Good catch. It worked, so we stopped? I'd like to revisit that math this summer. It doesn't always return an answer which converges, which suggests to me that something is wrong with it.
