Go to Post The only thing more dangerous than a Programmer with a screwdriver is a Hardware Designer with the root password... - kmcclary [more]
Unread 17-06-2016, 19:36
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
pic: OmniSwerve chassis Bottom View and Concept Discussion
Unread 17-06-2016, 19:38
FRC #0865
Re: pic: OmniSwerve chassis Bottom View and Concept Discussion
Sorry, double posted the pictures.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 17-06-2016, 20:07
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Good concept IMO. This would probably also be advantageous if a motor/gearbox/drive module failed, as it seems like it could be pulled along by just one wheel. All of the gears should probably be protected better so debris doesn't get in them.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 17-06-2016, 20:35
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
this is ridiculous, a complete waste of time, and probably not particularly effective. I love it!
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 17-06-2016, 20:48
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
The theoretical max speed is 1.414 times what the bot is geared to (because you can add the velocity vectors of X and Y travel after a fast turn, ideal hypotenuse is 2^0.5)
It would be a very interesting math problem to calculate the theoretical max speed. I don't think it's 1.414, because that either assumes the motor can get up to max speed immediately after a fast turn, or it assumes that omniwheels have no friction laterally. Instead, as the robot turns, it decelerates in one direction and accelerates in the other. With the omniwheels, the net acceleration will probably increase the speed. But to what maximum?
Unread 17-06-2016, 21:03
FRC #0865
"hypothetical" might be a better term for that. This unit is geared pretty low (free speed at 14.9 fps) so the acceleration on 6 CIMs should be pretty good. The lateral resistance of omni wheels is kind of an unknown at this point.
Unread 17-06-2016, 21:07
Chris is me's Avatar
AKA: Pinecone
I'm really having trouble seeing what this gains over a normal kiwi drive setup.
If you have six motors on it, you're going to have plenty of torque in any direction of travel even if all wheels aren't pointing in the same direction. You'll be able to do advanced maneuvers (simultaneous rotation + translation) with a kiwi drive, but not with this drive.
Unread 17-06-2016, 21:30
FRC #0865
You'd have one and a half times as much power in any direction ,assuming a power if 1 unit per wheel you'd get 2*cos(30)+1*cos(90)=1.73 to 1*cos(0)+2*cos(60)=2 for kiwi and 3*1=3 for omniswerve. If you have the motors mounted you might as well use them.
You are able to do advanced maneuvers with this because you can just tank turn at any time, there's no scrub from the omni wheels so even with the sub optimal platform it would still work.
Unread 17-06-2016, 22:35
AKA: Thomas
Team Role: CAD
I think we can all agree that this design is not meant to be realistic anyways.
Unread 17-06-2016, 23:27
Dan_Karol Dan_Karol is online now
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Maybe i'm missing something, but how does it turn?
If all pods are ganged together then you have no control over what your heading is or you have no ability to strafe.
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 17-06-2016, 23:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
TL;DR Trying to wrap my brain around what this does and why you'd want to do it.
If all the wheels steer in unison, you have crab drive - with the inherent [crab] inability to rotate the chassis (not good for a triangular chassis in most conceivable games) and the additional [omni] weakness of being highly vulnerable to cross-drive forces. I don't see any way to get anything faster than geared speed in this scenario, either.
If only the wheel near the steering motor is steered, I can imagine a scenario where you can get up some extra speed, though I haven't done the math to convince myself it's viable. If this is the case, why are the two non-steered wheels built up so they appear to be swerve modules?
Or is something else going on (e.g. one of the wheels steers counter to the other two, or something even more arcane)?
Edit:
Originally Posted by asid61 View Post
How are you getting above max speed?
drive straight to max speed, turn left at 90 degrees and accelerate in that direction to max speed. Because of the omni wheels, you actually (ideally) don't lose your forward momentum after turning and, as such, move in both directions at your maximum geared speed, hypotenuse of that vector triangle is 1.414 times the side length.
Maximum speed is achieved when the drag/frictional forces are equal to the drive forces, and the drive forces are applied. Once you turn the drive in another direction, you'll begin to slow in the direction you are moving. You may be able to achieve a bit better maximum velocity, but after accounting for the longer distance traveled, I don't see how you can achieve a higher net speed.
Edit2: That is, at maximum speed, saying you don't lose forward momentum, even ideally, is not valid. Maximum speed is inherently the result of significant loss of forward momentum due to friction.
Unread 17-06-2016, 23:59
FRC #0865
The way I have it is they all point in the same direction. You can tank turn in any orientation by simply driving one side forward and one side back. Only the pivots are chained together not the actual drive.
The reason you can't turn in conventional crab is because the drive is all chained together and because the wheel scrub from trying to tank turn is too significant.
here's a crude vector diagram of my 3 wheeled swerve rotating.
http://imgur.com/0HMYj0g
If they were traction wheels the steering would be awful (non existent) because the wheels would oppose the lateral forces exerted on them. With omni wheels this does not happen so it should be able to turn quite nicely.
Unread 18-06-2016, 00:48
Aren Siekmeier's Avatar
on walkabout
Pure silliness
Hahahahahahahahaha.
I love the three wheels though. Also, your packaging on a non-coax module is not bad.
Unread 18-06-2016, 01:17
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
How are you getting above max speed? You might get more power in a direction (like with a kiwi), but not more max speed.
The major advantage I can see to this is being able to run a crab drive without worrying about turning scrub, but at that point one might as well run mecanum or pure swerve. I think this would be usable for a team with low programming resources that wants to get into swerve (say during the build season) but wants a good backup plan for if it doesn't work out. Crab is significantly easier to program than full swerve.
Unread 18-06-2016, 07:06
FRC #0865
There are also the standard "butterfly" advantages of this over traction wheels. See 33 in 2014 for similar reason, why would they go for omnis over traction in a standard tank. This concept is silly but IMO does merit actual consideration, even as just a thought experiment; it has some significant advantages.
