Go to Post The only teams who have no chance of winning are those who believe they can't win. To quote the greatest athlete of our generation: "Limits like fears are often just an illusion." -- Michael Jordan - Karthik [more]
Unread 17-06-2016, 21:07
Chris is me's Avatar
AKA: Pinecone
Re: pic: OmniSwerve chassis Bottom View and Concept Discussion
I'm really having trouble seeing what this gains over a normal kiwi drive setup.
If you have six motors on it, you're going to have plenty of torque in any direction of travel even if all wheels aren't pointing in the same direction. You'll be able to do advanced maneuvers (simultaneous rotation + translation) with a kiwi drive, but not with this drive.
Unread 17-06-2016, 21:30
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
You'd have one and a half times as much power in any direction ,assuming a power if 1 unit per wheel you'd get 2*cos(30)+1*cos(90)=1.73 to 1*cos(0)+2*cos(60)=2 for kiwi and 3*1=3 for omniswerve. If you have the motors mounted you might as well use them.
You are able to do advanced maneuvers with this because you can just tank turn at any time, there's no scrub from the omni wheels so even with the sub optimal platform it would still work.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 17-06-2016, 22:35
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
I think we can all agree that this design is not meant to be realistic anyways.
Unread 17-06-2016, 23:27
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Maybe i'm missing something, but how does it turn?
If all pods are ganged together then you have no control over what your heading is or you have no ability to strafe.
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 17-06-2016, 23:56
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
TL;DR Trying to wrap my brain around what this does and why you'd want to do it.
If all the wheels steer in unison, you have crab drive - with the inherent [crab] inability to rotate the chassis (not good for a triangular chassis in most conceivable games) and the additional [omni] weakness of being highly vulnerable to cross-drive forces. I don't see any way to get anything faster than geared speed in this scenario, either.
If only the wheel near the steering motor is steered, I can imagine a scenario where you can get up some extra speed, though I haven't done the math to convince myself it's viable. If this is the case, why are the two non-steered wheels built up so they appear to be swerve modules?
Or is something else going on (e.g. one of the wheels steers counter to the other two, or something even more arcane)?
Edit:
Originally Posted by asid61 View Post
How are you getting above max speed?
drive straight to max speed, turn left at 90 degrees and accelerate in that direction to max speed. Because of the omni wheels, you actually (ideally) don't lose your forward momentum after turning and, as such, move in both directions at your maximum geared speed, hypotenuse of that vector triangle is 1.414 times the side length.
Maximum speed is achieved when the drag/frictional forces are equal to the drive forces, and the drive forces are applied. Once you turn the drive in another direction, you'll begin to slow in the direction you are moving. You may be able to achieve a bit better maximum velocity, but after accounting for the longer distance traveled, I don't see how you can achieve a higher net speed.
Edit2: That is, at maximum speed, saying you don't lose forward momentum, even ideally, is not valid. Maximum speed is inherently the result of significant loss of forward momentum due to friction.
Unread 17-06-2016, 23:59
FRC #0865
The way I have it is they all point in the same direction. You can tank turn in any orientation by simply driving one side forward and one side back. Only the pivots are chained together not the actual drive.
The reason you can't turn in conventional crab is because the drive is all chained together and because the wheel scrub from trying to tank turn is too significant.
here's a crude vector diagram of my 3 wheeled swerve rotating.
http://imgur.com/0HMYj0g
If they were traction wheels the steering would be awful (non existent) because the wheels would oppose the lateral forces exerted on them. With omni wheels this does not happen so it should be able to turn quite nicely.
