Go to Post Thanks Autodesk! - Al Skierkiewicz [more]
Unread 19-06-2016, 15:31
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Re: pic: OmniSwerve Pivot Top View
Originally Posted by Greg Woelki View Post
Rubberized?
The casing probably isn't adequately concentric with the shaft so the gear spacing could be pretty significantly off. That said, peoples get away with 10-32 screws in loose fit holes for gear spacing on drive gearboxes (when they don't use the flange for more precise centering). It might take a little finicking but I think it's certainly doable to use a clamp like this. As I understand it, gears can handle pretty significant misalignment if they aren't expected to run for very long.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
