Go to Post If you think that teams would never bypass the rules or do something unsafe (intentional or unintentional), I suggest you spend a weekend as an inspector. Every bad scenario that you can think of, we have seen. - Al Skierkiewicz [more]
View Poll Results: What is your favorite feature of the SD540?
Light Weight 25 20.33%
Low Cost 47 38.21%
Multi-Bank Option 31 25.20%
I do not like this product. 47 38.21%
Multiple Choice Poll. Voters: 123. You may not vote on this poll
  #181   Spotlight this post!
Unread 21-06-2016, 12:33
REVving up for a new season
FRC #2848 (All-sparks)
Re: SD540 Motor Controller
Originally Posted by JesseK View Post
I remember these being the cheapest when they came out, but perhaps the SPARKs came out after the SD540's and dove below the price point? Am I remembering this correctly?
We didn't learn about the SD540 until days before the public announcement, at which point our prices had already been set. The SD540 was available to purchase a few weeks prior to the SPARK, but their existence didn't influence our cost.
If I can step back from my obvious SPARK bias a bit, my main issue with the SD540 is that the calibration switch and brake coast mode switch is on the bottom of the unit. I don't understand from a user interface standpoint how this works for teams. Do teams have to lift up their motor controllers while the robot is powered and enabled to calibrate them? Also my team plays with the brake/coast mode all season for different applications and it would be frustrating to me to have to turn over each controller for access to this feature.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
  #182   Spotlight this post!
Unread 21-06-2016, 12:39
Michael Hill's Avatar
I just don't see how to get over this huge difference in performance;
http://www.ctr-electronics.com/downl...er-Testing.pdf
The fix for the SD540 power output is probably just a change in the MOSFETs or thermal characteristics. They probably just used MOSFETS with a higher Rds(on). I'm not sure of the actual topography of the SD540s, but I get an equivalent Rds(on) of ~ 17 mOhms with the SD540s. In comparison, the Victor SP has an equivalent of ~ 4 mOhms. When I say I don't know the topography, it'll be an H-bridge, but how many parallel MOSFETS there are on each leg is key. Also, I'm guessing the SRX has an additional current sense resistor over the SP, which would explain why the Victor SP tests better (just my guess). As for the SD540s, I'm betting when they designed it, they trusted the MOSFET data sheet. MOSFET Rds(on) specs in datasheets are some of the biggest lies ever. They'll give you the Rds(on) with a junction temperature of 20 degC on the front page, but when you heat it up to ~100 degC, it can change drastically. Always check the graphs.
  #183   Spotlight this post!
Unread 21-06-2016, 12:40
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Originally Posted by Anupam Goli View Post
Really? I thought the multi-bank feature sounded pretty cool. Sure the other specs of the controller are less desirable but maybe the next iteration will be better.
Heres the way I see it.
4 Victor SP's or 4 Talon SRX's side by side is 2.75" by 4.74" by 1.185"
A bank of 4 SD540's is 2.7" by 6.1" by 1.2"
So you get a larger footprint with the 'feature' that if one of the controllers in a bank fails you are stuck with a dead controller sitting on your robot.
Now, you could argue that Spark's have a larger footprint which is true. But even with the quantity of 4 they come in cheaper than the bank of 4 SD540's.
and their dimensions in line are not much bigger at
2.74" by 7.5" by 0.868
  #184   Spotlight this post!
Unread 21-06-2016, 19:40
Did anyone try using such a compact array? I'm worried about how hot the center two are going to get if they are mounted that way.
  #185   Spotlight this post!
Unread 21-06-2016, 20:03
Jared's Avatar
Jared Jared is offline
17 mOhm Rds on is really high for this type of motor controller. At 30 amps, which FRC robots will draw for a few seconds, you're dissipating 15.3 watts in your FETs!
It seems weird to have this so high - you'd almost have to go out of your way to find FETs with 8 mOhm Rds. There are tons of FETs designed for motherboard switching power supplies that do much, much better. It seems more likely there's some other issue, like V_gs dropping on the high side FET, or insufficient gate current, or possibly even thermal issue.
  #186   Spotlight this post!
Unread 21-06-2016, 20:16
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
We ran 4 Victor SPs side by side with a footprint of 4.82" * 2.5" * 1.22" with no problems. However, the motor controllers were staggered in a up-down-up-down pattern and raised about 2" above the electronics board, which could've helped with cooling.
  #187   Spotlight this post!
Unread 21-06-2016, 20:55
I agree it's too high. Looking at the pictures more closely, it looks like this is the MOSFET: http://www.nxp.com/documents/data_sh...N1R0-30YLD.pdf All looks fine to me (in fact, I think it's the same as, or at least related to, the one used in the Talon SRX as shown in this teardown: http://imgur.com/gallery/2xqoU). The current sense resister seems odd to me. I'm trying to make sense of the marking. The SRX uses a 0.5mOhm sense resistor (M50), but the SD540 has a marking of "50m", which doesn't make any sense to me since the math wouldn't add up (50mOhm). Is there an alternate interpretation of that marking?
Large picture of the SD540 here: https://images-na.ssl-images-amazon....1X6vyE3RyL.jpg
  #188   Spotlight this post!
Unread 21-06-2016, 21:46
Jared's Avatar
I think R50M is 0.5mOhm. It's kind of a weird label, but it's the only thing that makes sense. http://www.tai.com.tw/index.php/en/p...istors/111-rlf
What's a current sense resistor doing here though? I didn't know it needed to measure current.
Also - I just noticed it has 8 FETs (two in parallel everywhere), compared to the Talon's 4. Kind of odd.
  #189   Spotlight this post!
Unread 21-06-2016, 22:33
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Our four Talon SRX's for our drive were mounted side by side very closely and we had no problems with heating. It seems that the SRX's are very good about low heat loss.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
  #190   Spotlight this post!
Unread 21-06-2016, 22:37
NickE's Avatar
NickE NickE is offline
_
We ran 7 Talons in a row with no issues.
  #191   Spotlight this post!
Unread 21-06-2016, 22:50
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Same. We did that and even had them mounted under another plate and there were no issues.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #192   Spotlight this post!
Unread 22-06-2016, 07:08
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Alternate theory: It's a 0.5 Meg ohm and the purpose is to bleed off the capacitor when not in use.
  #193   Spotlight this post!
Unread 22-06-2016, 09:51
I'm wondering what the copper thickness of the board is. I see in the SD540 picture that solder is being used to lower the impedance of the traces (the blobs of solder you see on the copper), but it looks a little dodgy in some places (there are some places where no solder is on the traces like next to the nearest MOSFET). Also, if someone has a picture of the other side of the board, that would be cool to see.
