Go to Post "Look, it's already weight optimized!" - Samk [more]
Unread 21-06-2016, 18:58
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Powering an FRC-like system from a wall outlet
Originally Posted by kitare102 View Post
Thanks, this was a lot of help. Just to check, looking at a power supply like this: https://www.amazon.com/eTopxizu-Univ.../dp/B00D7CWSCG
Is it possible with this unit to have a line going out to the motor controller and then convert another line to 5v to power the control system?
I would say that should work, but if after looking at that power supply, I noticed two things; one, it doesn't have a built in port for a power cord, just terminals. This is linked below it on Amazon, and would allow you to use a standard computer power supply cord. The other thing I noticed is that the terminals on the power supply are almost completely exposed. Yes, they do appear to have a plastic cover, but it probably comes off so you can access the screws. Not too much of a problem for the 12 volt DC outputs unless something conductive falls on them, but the 120 volt AC input terminals are a different story... If you decide to use it, make sure the high voltage terminals are protected and that it's unplugged before doing any work on it.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
