| View Poll Results: What is your favorite feature of the SD540? | |||
| Light Weight |
25 | 20.33% |
| Low Cost |
47 | 38.21% |
| Multi-Bank Option |
31 | 25.20% |
| I do not like this product. |
47 | 38.21% |
| Multiple Choice Poll. Voters: 123. You may not vote on this poll | |||
#181
Re: SD540 Motor Controller
If I can step back from my obvious SPARK bias a bit, my main issue with the SD540 is that the calibration switch and brake coast mode switch is on the bottom of the unit. I don't understand from a user interface standpoint how this works for teams. Do teams have to lift up their motor controllers while the robot is powered and enabled to calibrate them? Also my team plays with the brake/coast mode all season for different applications and it would be frustrating to me to have to turn over each controller for access to this feature. Last edited by Greg Needel : 21-06-2016 at 12:44. |
#182
4 Victor SP's or 4 Talon SRX's side by side is 2.75" by 4.74" by 1.185" A bank of 4 SD540's is 2.7" by 6.1" by 1.2" So you get a larger footprint with the 'feature' that if one of the controllers in a bank fails you are stuck with a dead controller sitting on your robot. Now, you could argue that Spark's have a larger footprint which is true. But even with the quantity of 4 they come in cheaper than the bank of 4 SD540's. and their dimensions in line are not much bigger at 2.74" by 7.5" by 0.868 Last edited by Sperkowsky : 21-06-2016 at 12:47. |
#184
Did anyone try using such a compact array? I'm worried about how hot the center two are going to get if they are mounted that way.
#185
17 mOhm Rds on is really high for this type of motor controller. At 30 amps, which FRC robots will draw for a few seconds, you're dissipating 15.3 watts in your FETs!
It seems weird to have this so high - you'd almost have to go out of your way to find FETs with 8 mOhm Rds. There are tons of FETs designed for motherboard switching power supplies that do much, much better. It seems more likely there's some other issue, like V_gs dropping on the high side FET, or insufficient gate current, or possibly even thermal issue. |
#186
We ran 4 Victor SPs side by side with a footprint of 4.82" * 2.5" * 1.22" with no problems. However, the motor controllers were staggered in a up-down-up-down pattern and raised about 2" above the electronics board, which could've helped with cooling.
#187
Large picture of the SD540 here: https://images-na.ssl-images-amazon....1X6vyE3RyL.jpg |
#188
What's a current sense resistor doing here though? I didn't know it needed to measure current. Also - I just noticed it has 8 FETs (two in parallel everywhere), compared to the Talon's 4. Kind of odd. |
#189
Our four Talon SRX's for our drive were mounted side by side very closely and we had no problems with heating. It seems that the SRX's are very good about low heat loss.
#190
We ran 7 Talons in a row with no issues.
#191
Same. We did that and even had them mounted under another plate and there were no issues. |
#192
Alternate theory: It's a 0.5 Meg ohm and the purpose is to bleed off the capacitor when not in use.
#193
I'm wondering what the copper thickness of the board is. I see in the SD540 picture that solder is being used to lower the impedance of the traces (the blobs of solder you see on the copper), but it looks a little dodgy in some places (there are some places where no solder is on the traces like next to the nearest MOSFET). Also, if someone has a picture of the other side of the board, that would be cool to see.
