Go to Post Almost as if there's...co-opertition? - Michael Hill [more]
Unread 21-06-2016, 15:18
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
HTD Belt Stock
I'm building a linear motion component, and need belts for 24t pulleys that have about 52.5" CC distance. For this application, I don't need continuous belts. Does anyone know where I can find non-continuous HTD belt stock?
Unread 21-06-2016, 15:24
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
Re: HTD Belt Stock
http://www.beltingonline.com/rubber-...h-belting-740/
Or just buy a reasonably large closed belt and cut it into an open one yourself if the pricing works out better that way.
2013 - 2016 - Mentor - Robochargers 3005
2014 - 2016 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 21-06-2016, 15:32
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: HTD Belt Stock
SDP-SI also carries it.
Unread 21-06-2016, 15:38
AKA: Eric
Re: HTD Belt Stock
I'm not finding open length belts on SDP-SI anywhere, can you provide a link?
Unread 21-06-2016, 15:41
Re: HTD Belt Stock
http://www.sdp-si.com/catalogs/D810.php
You'll have to go into the catalog, section 2, then contact a sales rep.
Unread 21-06-2016, 17:01
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: HTD Belt Stock
Try this:
https://shop.sdp-si.com/catalog/powe...onics&cid=p343
If that doesn't work, go to sdp-si.com, then "Buy Online" (top right), then click on "Belts and Cables". Then hit "Timing Belts (Open Ended) (metric)" and select "Classic Grid View" on the top-left. Then select what pitch/profile you want from the drop down on the left, and the belt width next to that.
We sourced 25mm wide HTD belts last year for use on our elevator. We didn't have a single failure all year, probably because that was waaay overspec'd.
As a side note, GT2 and GT3 is usually better to use than HTD, but either is very strong anyway.
Unread 21-06-2016, 17:17
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: HTD Belt Stock
Just buy a standard size that's about five or six inches longer than needed and simply cut it in half. That will leave room to clamp the cut sections. It will be far cheaper then buying some specialized open belting.
I've cut 15 MM HTD Belt with a simple pair of scissors.
GT3 is a better overall option; but HTD is far better supported by Vex & AM pulleys so we have stuck with HTD.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 21-06-2016, 17:36
AKA: Eric
Re: HTD Belt Stock
The main problem with finding a continuous belt and cutting it is that I need about 3 meters of belt. The belts I've found of that size aren't notably cheaper than an open length belt from belting online.
Unread 21-06-2016, 17:45
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: HTD Belt Stock
It looks like you can get a 624 tooth (3.12m) 15mm wide closed belt from SDP-SI for $61, whereas 3m of the same type of open belting is $66. I always thought open belting was cheaper, but I guess I was wrong. However, they appear to only have a single one in stock, so if you want more than 1 you're out of luck.
Unread 22-06-2016, 11:25
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a jewel in the roughsilverD is a jewel in the roughsilverD is a jewel in the roughsilverD is a jewel in the rough
Re: HTD Belt Stock
You might want to check out polytech. They have many options, great prices, and ship right away.
Nate
