Go to Post Do not under estimate the wood bots and brave little toasters! - hipsterjr [more]
Unread 22-06-2016, 19:54
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Encoder Conundrum
So, our team has had season-long difficulties with our encoders on our drive train (This one).
Consistently, at first, we had our left encoder working and the right one not working. We worked around this, using only the left side for distance. However, we decided to fix this in the off-season. We replaced both encoders (left & right) for brand new ones. We also tested the wires for shorts and continuity where they should/shouldn't be. All fine. The problem persists.
Our next step was to try to connect them directly through the Talon SRX with the little expansion board for wire --> ribbon cable. Now, the right encoder started working and the left one didn't. Thinking this was the wires, we replaced & tested all four parts (2 ribbon cables & 2 encoder wires). No difference. The problem persists with the left side now.
We are going to try to switch to magnetic encoders, but it's still an interesting conundrum as to why all of this happened. Why was one working, and then they switched?
Any advice is helpful, Thanks!
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 22-06-2016, 20:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Encoder Conundrum
I don't see enough information to make a likely call. If you have access to an oscilloscope, My first recommendation would be to look at the output of the two encoder channels (relative to signal ground) vs time. Do you get a good quadrature signal? (I'm assuming quadrature encoders; most of the ones used in FRC are.)
If you do not have access to an o-scope, try swapping the Talon SRXs - move both the power wires to the motors and the encoder cable, and program the channels as swapped (unless you want to re-address the Talons). If the problem follows the encoder/cable, the problem is likely there. If it follows the talon, then I would suspect a software issue, though it is possible that something is wrong with that talon.
Unread 22-06-2016, 22:09
page2067's Avatar
page2067 page2067 is online now
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
So many complain over those encoders - but we used them from 2009 through 2015 with generally good results. yes sometimes not, these were usually due to either 1) contamination/ scratches of the metal optical target, or 2) associated with the connector, usually after an attempt to unplug and replug the connector - a delicate operation to be avoided.
they are a little fussy, prompting many to shift to other options (including us last year, not necessarily just the magnetic encoders, some go for Grayhill 63R's and another is the AM CIMcoder), but once they are set right up, they work fine. We still have some in inventory, so will use them at some point.
Unread 22-06-2016, 23:14
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
This probably isn't it, but make sure the ribbon cables are plugged in the right way on both sides. We had this issue during build season
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
