Go to Post This forum is a really great tool to get people connected to the rest of FIRST communities, as well as a great place to learn from other people and share a little part of yourself. - Ken Leung [more]
Unread 05-21-2016, 12:05 AM
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
GRIP Help
Here is the error that I keep on getting
I am running 1.4.0 on a Kangaroo (I would update but I think a Kangaroo is only 32 bit)
ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
ERROR: V4L: setting property #16 is not supported
[code]/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
May 21, 2016 4:53:46 AM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.4.0
platform: /Linux/arm/
May 21, 2016 4:53:52 AM edu.wpi.grip.core.Main start
INFO: Loading file /home/lvuser/project.grip
May 21, 2016 4:53:54 AM edu.wpi.grip.core.util.service.LoggingListener starting
INFO: [CameraSource] Starting
May 21, 2016 4:53:54 AM edu.wpi.grip.core.operations.composite.PublishVide oOperation lambda$new$0
INFO: Starting camera server
May 21, 2016 4:53:55 AM edu.wpi.grip.core.util.service.LoggingListener starting
INFO: [PipelineRunner] Starting
May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main start
INFO: SUCCESS! The project is running in headless mode!
OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp, line 3208
May 21, 2016 4:53:55 AM edu.wpi.grip.core.Step runPerformIfPossible
WARNING: The CV resize operation did not perform correctly.
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize
at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method)
at edu.wpi.grip.generated.opencv_imgproc.Resize.perfo rm(Resize.java:61)
at edu.wpi.grip.core.Operation.perform(Operation.java :92)
at edu.wpi.grip.core.Step.runPerformIfPossible(Step.j ava:152)
at edu.wpi.grip.core.PipelineRunner.runPipeline(Pipel ineRunner.java:184)
at edu.wpi.grip.core.PipelineRunner.access$100(Pipeli neRunner.java:35)
at edu.wpi.grip.core.PipelineRunner$1.runOneIteration (PipelineRunner.java:68)
at com.google.common.util.concurrent.AbstractSchedule dService$ServiceDelegate$Task.run(AbstractSchedule dService.java:189)
at com.google.common.util.concurrent.Callables$3.run( Callables.java:100)
at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: The CV resize operation did not perform correctly.
WARNING: The HSL Threshold operation did not perform correctly.
java.lang.IllegalArgumentException: HSL Threshold needs a 3-channel input
at edu.wpi.grip.core.operations.composite.HSLThreshol dOperation.perform(HSLThresholdOperation.java:68)
SEVERE: The HSL Threshold operation did not perform correctly.
VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP
VIDEOIO ERROR: V4L: setting property #16 is not supported
May 21, 2016 4:53:55 AM edu.wpi.grip.core.operations.network.networktables .NTManager lambda$new$0
INFO: NetworkTables: Dispatcher.cpp:392 client: CONNECTED to server 172.22.11.2 port 1735
May 21, 2016 4:53:56 AM edu.wpi.grip.core.Main onExceptionClearedEvent
INFO: Exception Cleared Event
OpenCV Error: Insufficient memory (Failed to allocate 921600 bytes) in OutOfMemoryError, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/alloc.cpp, line 52
OpenCV Error: Assertion failed (u != 0) in create, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp, line 411
May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener starting
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
VIDIOC_STREAMON: Bad file descriptor
May 21, 2016 4:55:01 AM edu.wpi.grip.core.GRIPCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[Webcam 0 Service,5,main]
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp:411: error: (-215) u != 0 in function create
at org.bytedeco.javacpp.opencv_videoio.cvRetrieveFram e(Native Method)
at org.bytedeco.javacv.OpenCVFrameGrabber.grab(OpenCV FrameGrabber.java:237)
at edu.wpi.grip.core.sources.GrabberService.runOneGra b(GrabberService.java:69)
at edu.wpi.grip.core.sources.GrabberService.run(Grabb erService.java:61)
at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:60)
May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener failed
SEVERE: [CameraSource] Failed from: RUNNING
SEVERE: [CameraSource] Failed from: STARTING
edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start
at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51)
at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54)
Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?)
at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214)
at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49)
... 3 more
May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: Camera service crashed
... 3 more
May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting
May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
Unable to stop the stream.: Bad file descriptor
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
... 3 more
Unable to stop the stream.: Device or resource busy
VIDIOC_QUERYCTRL: Bad file descriptor
... 3 more
... 3 more
... 3 more
[ERROR] Too much output to display. Discarding the rest.
[\CODE]
The "VIDIOC_QUERYCTRL: Bad file descriptor" is since i turned off the robot
<grip:Pipeline>
  <sources>
    <grip:Camera>
      <property name="deviceNumber" value="0"/>
    </grip:Camera>
  </sources>
  <steps>
    <grip:Step name="Publish Video">
      <grip:Input step="0" socket="0"/>
      <grip:Input step="0" socket="1">
        <value>80.0</value>
      </grip:Input>
    </grip:Step>
    <grip:Step name="Publish Number">
      <grip:Input step="1" socket="0"/>
      <grip:Input step="1" socket="1">
        <value>frameRate</value>
      </grip:Input>
      <grip:Input step="1" socket="2">
        <value>true</value>
      </grip:Input>
    </grip:Step>
    <grip:Step name="CV resize">
      <grip:Input step="2" socket="0"/>
      <grip:Input step="2" socket="1"/>
      <grip:Input step="2" socket="2">
        <value>0.6</value>
      </grip:Input>
      <grip:Input step="2" socket="3">
        <value>0.6</value>
      </grip:Input>
      <grip:Input step="2" socket="4">
        <value>INTER_LINEAR</value>
      </grip:Input>
      <grip:Output step="2" socket="0" previewed="false"/>
    </grip:Step>
    <grip:Step name="HSL Threshold">
      <grip:Input step="3" socket="0"/>
      <grip:Input step="3" socket="1">
        <value>
          <double>53.41726618705036</double>
          <double>100.0</double>
        </value>
      </grip:Input>
      <grip:Input step="3" socket="2">
        <value>
          <double>38.98381294964029</double>
          <double>222.36348122866895</double>
        </value>
      </grip:Input>
      <grip:Input step="3" socket="3">
        <value>
          <double>105.48561151079136</double>
          <double>215.83617747440272</double>
        </value>
      </grip:Input>
      <grip:Output step="3" socket="0" previewed="false"/>
    </grip:Step>
    <grip:Step name="Find Contours">
      <grip:Input step="4" socket="0"/>
      <grip:Input step="4" socket="1">
        <value>false</value>
      </grip:Input>
      <grip:Output step="4" socket="0" previewed="false"/>
    </grip:Step>
    <grip:Step name="Filter Contours">
      <grip:Input step="5" socket="0"/>
      <grip:Input step="5" socket="1">
        <value>0.0</value>
      </grip:Input>
      <grip:Input step="5" socket="2">
        <value>0.0</value>
      </grip:Input>
      <grip:Input step="5" socket="3">
        <value>0.0</value>
      </grip:Input>
      <grip:Input step="5" socket="4">
        <value>1000.0</value>
      </grip:Input>
      <grip:Input step="5" socket="5">
        <value>0.0</value>
      </grip:Input>
      <grip:Input step="5" socket="6">
      </grip:Input>
      <grip:Input step="5" socket="7">
        <value>
          <int>0</int>
          <int>100</int>
        </value>
      </grip:Input>
      <grip:Output step="5" socket="0" previewed="true"/>
    </grip:Step>
    <grip:Step name="Publish ContoursReport">
      <grip:Input step="6" socket="0"/>
      <grip:Input step="6" socket="1">
        <value>myContoursReport</value>
      </grip:Input>
      <grip:Input step="6" socket="2">
        <value>true</value>
      </grip:Input>
      <grip:Input step="6" socket="3">
        <value>true</value>
      </grip:Input>
      <grip:Input step="6" socket="4">
        <value>true</value>
      </grip:Input>
      <grip:Input step="6" socket="5">
        <value>true</value>
      </grip:Input>
      <grip:Input step="6" socket="6">
        <value>true</value>
      </grip:Input>
      <grip:Input step="6" socket="7">
        <value>true</value>
      </grip:Input>
    </grip:Step>
  </steps>
  <connections>
    <grip:Connection>
    </grip:Connection>
    <grip:Connection>
    </grip:Connection>
    <grip:Connection>
      <grip:Output source="0" socket="0" previewed="false"/>
    </grip:Connection>
    <grip:Connection>
    </grip:Connection>
    <grip:Connection>
      <grip:Output source="0" socket="1" previewed="false"/>
    </grip:Connection>
    <grip:Connection>
    </grip:Connection>
    <grip:Connection>
    </grip:Connection>
  </connections>
  <settings>
    <teamNumber>0</teamNumber>
    <publishAddress>roborio-0-frc.local</publishAddress>
    <deployAddress>10.36.47.2</deployAddress>
    <deployDir>/home/lvuser</deployDir>
    <deployUser>lvuser</deployUser>
    <deployJavaHome>/usr/local/frc/JRE/</deployJavaHome>
    <deployJvmOptions>-Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError</deployJvmOptions>
  </settings>
</grip:Pipeline>
That is my grip config
Can someone help me debug
Go Team 3647 Millennium Falcons!
Unread 05-21-2016, 01:21 AM
AustinShalit's Avatar
AustinShalit AustinShalit is offline
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: GRIP Help
Please open an issue on Github for support from the GRIP team.
Unread 06-23-2016, 04:58 PM
minutebot minutebot is offline
Programming Captain
FRC #4536 (The Minutebots)
minutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of light
Re: GRIP Help
Unfortunately, this issue has been reported numerous times it looks like. I haven't seen any solutions yet either. Are there any solutions yet that anyone is aware of? Our team just started working with GRIP for the summer and so I don't really know how to continue if we're running into this known problem.
