#9
Re: Demonstration event robot comm
First off - thanks to all the suggestions I received.
Everything came off great! I purchased a middle of the road router with dual-band capability. Brought with me a set of Cat5 cables for the drivestations. I made sure I had the latest radio configuration software. The basic process was to Setup the SSIDs for the two router bands, Setup a WPA password for each band, Change the admin password on the router, Configure the router as 10.0.0.1 with a subnet mask of 255.0.0.0 The real key on radio setups was to use the 'FMS-Lite Mode' in 'Tools'. Most of the radios took the configuration on the first pass. I had forgotten to read up on the drive station configuration. Once I set the IP address of the drive station to 10.TE.AM.6, everything worked fine! Attached are the step-by-step instructions I created. Replace my #1018 centric jargon with your own choices, and away you go! One comment: Using an independent workstation to check for connected devices on the router was very helpful. That way I could verify wireless comm to the robots and cabled comm to the drive stations. This removed a lot of guesswork. Have fun, good luck to all! |
