Go to Post There's 2 things that are really hard in CS - naming things, cache invalidation, and off by one errors. - Andrew Schreiber [more]
Unread 24-06-2016, 00:30
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: compact reversed cim gearbox and output shaft question
The drawing indicates it's a metric roll pin size 3mm x 18mm. McMaster Carr carries that size.
Just put it in a hand arbor press, it should be easy to remove and install. A M2.5 cap head bolt from the hardware store would work to push the old one out.
http://content.vexrobotics.com/vexpr...g-20141016.PDF
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
