Go to Post Come on, Dave! We need more lyrics! (I'll bring you fresh KK doughnuts at VCU's regional! :D ) - Squirrelrock [more]
Unread 24-06-2016, 11:51
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
Re: Help tracking down a possible cause for robot disconnects
Originally Posted by phargo#1018 View Post
Can you elaborate on the conditions at your demonstration even?
We were using the offseason FMS on a 5 Ghz I believe. It was at the Houston Comicpalooza, so if it were only comm issues I'd feel pretty comfortable trying to blame the environment. Other than that, the environment wasn't any different than you'd expect from a offseason or in-season event. Real field components, real carpet, etc.
Originally Posted by Team34Guy View Post
The barrel power connector can sometimes momentarily lose connection when it's jarred. This can cause your comms to shut down for close to a minute while the radio reboots. We had this happen in competition.
Yes - our barrel connection was really bad. We changed over to PoE. For awhile we had both the PoE and the barrel connector - but found that we could get radio resets with both plugged in. Using only the PoE reliably kept power to the radio when we would manually try to do vibration tests. I also didn't see the radio go through what I believe is it's power cycle sequence. That doesn't mean there's not a bad internal connection however that could keep power while losing connection
Originally Posted by tr6scott View Post
So did you?
Are you using 2.4GHz?
Did you try 5GHz?
We did not use the wifi analyzer app. I will try to do that next time I'm at the school. Once we got the rio to stop resetting and we kept comm, I was pretty anxious to head back to work. I didn't even think to look at the rio logs/lost packet count until I was on my way out. I might look into getting a 5 Ghz adapter if it looks like the 2.4 Ghz is a problem at the school, but it's at least a good enough evironment to drive and test in.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
