Go to Post I just weighed myself and I have gained two pounds since last Saturday. Thats a sign of a good robotics team. - russell [more]
Unread 24-06-2016, 15:51
Chris is me's Avatar
AKA: Pinecone
Re: 6 wheel drop center drive train
Originally Posted by asid61 View Post
We tried 1/8" in 2014 and it was very noticeable. I've always thought that something between 1/16" ad 3/32" is a better drop for firm treaded wheels like blue nitrile.
That is largely because the 1/8" "standard" was settled on back when frame perimeters were 38x28. In 2014, most wheelbases were 28x28, so they may have been able to turn with very little or even no drop depending on the wheel choice and setup.
Unread 24-06-2016, 16:01
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
For reference, we used 3/16" drop with the AM pneumatic wheels. Zero issues with turning. Our setup was not standard tho. We had 8WD but performed more like a wide 6WD; our front wheels were raised 2" off the ground. So for us 3/16" was plenty.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 24-06-2016, 16:02
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
What did people run in 2009, out of curiosity? Were drops even used?
As an unrelated side note, using omni wheels on the corners instead of treaded wheels will of course greatly reduce the required drop.
No need for a drop in 2009 because of the lower CoF, I think a lot of bots went with 4wd because of it. You see the same thing in battlebots too because of the steel floor.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 24-06-2016, 16:28
AKA: Pinecone
While CoF was a factor, a much bigger factor was that nearly every competitive robot in 2009 already had a wheelbase wider than it was long, and didn't need a drop center to create this effect.
You can see this effect in games like 2012, teams who built wide robots did not need a drop center at all in order to turn.
Unread 24-06-2016, 17:04
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
It was also when teams were running 4 inch or smaller high friction wheels. The 1/8 drop has been further standardized by the advent of the versablock, which when applied in a certain way in wcd configuration create a 1/8 drop.
We historically have tried to minimize the drop for better or worse. This year we were able to pull off 3/32 on the 8in AM pneumatic wheels.
Unread 24-06-2016, 20:28
Originally Posted by Chak View Post
The concept is kind of correct. Still, I think what EricH was getting at was that 0.375" is not the absolute number due to other factors. For example, a drivetrain 48" long should have a different dropped distance compared to a drivetrain 20" long. A drop of .375" might not have the "upper hand" in both situations.
This is exactly what I was getting at.
@ ModMaster: I know the physics, at least in broad terms. You simply rehashed the broad physics without giving any numbers--even situational ones--to back up your assertion that "this dimension is the best". Just so you're aware, I was a student back when the WCD was introduced, in the area it was introduced in, and had the opportunity to learn about that drive, including the drop, from the teams that developed it.
If you're going to assert a blanket statement that "X is the best", this is a group of engineering types. You'll get an average of 1.33 counter-anecdotes per person on it not being optimal for a different configuration. (BTW, remember that 85% of statistics are made up on the spot--but in this post, it's 66%.)
