Small Pneumatic Wheels
Hi,
Does anyone know of a place to purchase small pneumatic wheels? I'm looking for something in the 4" - 5" OD range. Smaller would probably be OK too. I ultimately just need an inner and tire (not the hub), but a complete wheel would be fine as well. Thanks! |
Re: Small Pneumatic Wheels
I wasn't sure if they were avialable, then I thought about R/C airplanes that sometimes have small pneumatics. Here's one link I found. Try adding a combination of hobby, aircraft, and R/C to your searches.
I did a quick search and found an electric scooter wheel. Not sure of the size.
https://www.amazon.com/Universal-119...1033&sr =1-14 Also found this 5" wheel. https://www.amazon.com/Dynabrade-944...Y51 YPV82MEFZ This wheel claims to have a 3.25" hub. https://www.zoro.com/b-p-manufacturi...f-00505694526f Links for electronic skateboard http://www.enertionboards.com/pages/...cnc-alloy-rim/ https://www.google.com/search?q=pneu...-FQGV_VtTlM%3A Their might also be used by electric wheel chairs or hoverboards. Another idea is to search for "rubber stroller wheels" Dave |
The issue you might see with airplane wheels is that they are designed for takeoff, landing, and some taxiing. Continuous ground use might cause excessive wear. Also, they don't seem like they would be very good at transmitting torque, but I could be wrong about that. |
