Go to Post “Coming together is a beginning; keeping together is progress; working together is success.” - Henry Ford - hiyou102 [more]
Unread 25-06-2016, 19:52
DrewMatic's Avatar
DrewMatic DrewMatic is offline
Djibouti
AKA: Drew T
FRC #0240 (T.E.M.P.E.S.T)
DrewMatic is an unknown quantity at this point
Gearboxes
Hey everyone. I'm from 240 T.E.M.P.E.S.T and I'm trying to do some research. Last year we used tough box minis with mecanum wheels which worked pretty well. This year we used 2 speed supershifter gearboxes which were slow in low gear and jerked coming into low gear from high gear as well as into high gear.
I know there has to be a variety of different gearboxes to choose from. Is there any ones that your teams have used which worked pretty well in past years?
Thanks, Drew
Projects we have completed demonstrate what we know, but future projects decide what we learn.
Unread 25-06-2016, 20:10
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: Gearboxes
461 has used toughbox minis in the drivetrain for 2014 and 2015. This year we used sonic shifters. We liked the toughbox minis since they were so simple to integrate into our sheet metal drivetrain (direct drive using the frame as the output plate). The sonic shifter worked well for us all season until we sheared the pin in the dog gear. We had been using the internals of a super shifter from '08 so the dog gear/roll pin was the older revision than the current model. I'd also recommend not running the shifter on 60 psi (we feel comfortable with 35 psi).
In regards to the "jerk" when shifting, you might experiment with ramping your motors and auto shifting for a smoother more efficient drive.
461 Westside Boiler Invasion
45 Technokats
Knufire Knufire is offline
Re: Gearboxes
Originally Posted by DrewMatic View Post
...which were slow in low gear
Most COTS gearboxes actually have multiple ratio options that you can try. Did you try swapping the gears in your SuperShifter for a faster low gear? Ratio selection is a bit of a seperate topic from "What gearbox should I buy?".
Were you shifting with servos or pneumatics?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 25-06-2016, 20:21
DrewMatic's Avatar
Djibouti
AKA: Drew T
Re: Gearboxes
We were talking about programming them to auto shift to low gear before stopping completely for less jerk. Thanks!
Unread 25-06-2016, 20:23
DrewMatic's Avatar
Djibouti
AKA: Drew T
Smile Re: Gearboxes
Didn't think about changing gears for faster lower speed. I will use that in the future. And we used pneumatics for shifting gears.
Unread 25-06-2016, 20:38
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: Gearboxes
There's been quite a few gearbox threads that you could look at. We used vex ball shifters, custom AM super shifters, and various AM single speeds (Nanobox, Toughbox, etc); all with good success.
Lubrication and attention to detail when assembling gearboxes is critical.
We generally choose our gearboxes based on the drive type, and wheel size, and desired speeds.
For a CIM
Wheel Speed = (4455rpm/60 sec) * ( 1/gear ratio) * (wheel size/12")*3.14
For a shifter size your high speed gear ratio to ~15 ft/sec and the low speed will just fall out of the high/low ratio. For a single speed aim closer to 12 ft/sec.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 25-06-2016, 22:39
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Gearboxes
I really doubt your problem is that you bought the wrong gearbox. My first guess would be that you're shifting at the wrong speed. There is an optimal speed for up-shifting and down-shifting. You want to look at the acceleration vs. speed curve for your drivetrain with that gearbox and shift where the curves for the high and low gears cross. This means you won't experience sudden changes in acceleration because they're matched (fun fact: "jerk" is actually the technical term for rate of change of acceleration). This can be done theoretically, but you can also play with it and try different speeds (if you'd like help let me know). Setting these speeds and auto-shifting is highly highly recommended. Also note that (1) the optimal speeds are different for up and down shifting because gearbox efficiency acts differently each way (hurts when accelerating, helps when decelerating) and (2) if you have one shifting speed and you're driving near that speed, it may shift back and forth repeatedly which is not good.
Rahul's question about servo vs. pneumatic shifting gets at another possible reason for that jerk. I don't think pneumatic shifter would have trouble, though.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 26-06-2016, 12:33
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Re: Gearboxes
If you want to see what gearboxes are out there you can compare them at http://findrobotparts.com/gearboxes
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
