Go to Post FIRST is all about going past theoretical limits. - Foster [more]
Unread 24-06-2016, 01:42
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant future
Is there a bare bones/minimal dashboard example?
As in the title, is there a minimal example for the dash? Basically I want my front panel to start with nothing and the block diagram to only contain code necessary to set up communications.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
Unread 24-06-2016, 05:07
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Re: Is there a bare bones/minimal dashboard example?
I don't think such thing exists but our team has successfully managed to remove unwanted tabs that come with the basic dashboard such as the Commands and Test tabs.
It requires some rewiring and changes in subVIs that might seem problematic to touch but it didn't have impact on the overall performance of the dashboard.
(Even though I cannot guarantee that it won't cause you any problems)
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 24-06-2016, 11:07
Rather than removing most of what's there, it might be easier to start with the full-featured example dashboard and add a blank panel on top of everything else. Or, if you like the camera view, just put what you want in a tab that is active by default.
What do you want your dashboard program to do?
Unread 24-06-2016, 16:15
jman4747's Avatar
AKA: Josh
Team Role: CAD
I'll probably just add the panel. The point would mainly be to make an interface from scratch without the auto sizing and without deleting anything that would kill communications. I also wanted it to be a learning experience.
I was thinking of making one from scratch using TCP and UDP packets instead of network tables so the students can get a feel for some of the lower level networking. Then over time we build in our own functionality in as we want and do it as a class.
#banthebag
#RIBMEATS
Unread 26-06-2016, 19:57
jman4747's Avatar
AKA: Josh
Team Role: CAD
I tested these yesterday and they worked on our robot. The client is the Dash and the server runs on the Rio.
ID:	20874  Click image for larger version
#banthebag
#RIBMEATS
