#16
Re: Rules Change I Would Like to See - Batteries
Finally, If you really want that separate USB battery-power, charge up an old laptop, and power your pi off its USB port. There's no rule that says you have to turn the laptop on, much less do any processing on it. If you can use a classmate from a KoP, you won't even have to list any dollar cost in the BoM. |
#17
As I see it. The problem the second battery solves is not losing your sensors and CPU from brown outs. The old (pre 2009) control system had a battery for this purpose because a brown out would cause a loss of control without disabling the robot. A second control power battery Powering the Rio and radio along with other custom circuits would solve a lot of issues. It would also add cost and complexity to the robot.
Would another possibility for the auxiliary processing be the android system used in FTC? The come with batteries and meet the COTs definition. |
#18
A cool idea, but I think the VRM (or a second or third VRM as needed) would do the trick.
We powered a Pi and an IP camera (and its LED ring light) off the VRM on our competition robot. On our practice bot, where we were a little less, uh, picky, we plugged the Pi into the USB port on the RoboRio. |
#19
The DC-DC converter plan seems like a better idea. |
#20
The safety aspect can be dealt with fairly easily. Cost and complexity still remain. The battery powered tool industry has pretty much gone to Li ion for everything except the bottom line tools. They get badly abused and have a low risk of fire/explosions. First could pick one or two commercial solutions and restrict maximum current draw and require specific chargers.
Another option for Arduino and PIs is somebody to package it with a battery and case. As long a it a company and they make it available for sale, it becomes a legal COTs device. (insert the usual future rules disclaimer here). Make it nice enough and maybe AndyMark would stock it for you. |
#21
Having a separate battery isn't without its own concerns. Assuming this became legal, you just know there will end up being a team somewhere, sometime that will be kicking themselves for losing a key match because they forgot to charge the battery pack powering their vision processing system.
#22
Hey look! It's a raspberry pi with a battery: https://www.sparkfun.com/products/13896
Ok, seriously, I agree with OP that this is a topic that needs to be dealt with. My suggested rule change is simple though. Just enable teams to use all batteries outside of the standard robot battery provided they do not interfere with the control pathways for any motors, they can be removed and disconnected quickly/easily, and they do not appear to be unsafe to a reasonably astute observer (no exposed wires, held securely, can't be easily punctured, well protected, etc). Quote:
For one, enabling the use of all batteries means the inspectors don't have to look at an approved list or deal with the currently ambiguous ruling of only allowing non-standard batteries that are "integral to" a COTS computing device.... which by the way, I'd like to know if this flashlight (http://www.lightmalls.com/nextorch-p...4aAvW 98P8HAQ) counts as a COTS computing device since it is programmable. Let's talk safety with alternative battery sources. If the concern is that something is going to catch fire then coin cell batteries and USB power supplies aren't likely to do it. I'm not saying they can't but they are common components (Sorry FRC fans but those crappy Chinese USB power supplies are a lot more common than FRC batteries) and I suspect the likelyhood of a fire is about the same as the chances of one from the standard robot battery we all know and love so can we ignore this facet of safety and move on? Not to mention that the same crappy Chinese batteries are legal provided they are "integral to" a COTS computing device. The real issue/fear is that a robot or robot mechanism will remain powered up and running. I believe that if the team can demonstrate to an inspector that the power source does not interface with the power for a motorized mechanism or drivetrain then it should be legal. I believe teams already have to do this if they have an "integral" power supply for a COTS computing device on board... and if they don't then they should. Also, I want a ruling about super capacitors while we're at it. They are circuit components and not batteries so they are legal for keeping a raspberry pi powered right? While I disagree with the way the OP worded his initial post, this issue is a sore spot for me as well and I do think FRC should address it in a manner similar to the "allow but educate" style that they have adopted in the recent years. Come on KOP team, Frank, and LRIs... how about showing some love for additional power sources for computing devices? |
#23
That's not what that rule means. It gives you permission to break the one wago one load rule with up to 3 VRMs. It doesn't limit you to 3 additional VRMs, you could have as many as you want limited by the number of 20amp breaker slots there are * 3 VRMs.
#24
If FIRST partnered with Samsung or another reliable company to supply teams with a FIRST legal battery pack, that would be a good solution to the problem without allowing weird loopholes or dangers. |
#25
More seriously, inspection is already a challenge for many inspectors; there should be a better reason than this to make it more difficult. If FRC can find a standard 5V power source for which they can provide a concise list or (even better) get something donated as part of the KoP, wonderful! Otherwise, this is (IMHO) a pound of solution for an ounce of problem. |
#27
Again, the safety concerns come from something going boom or something moving when it shouldn't be. Or maybe you are worried about someone being shocked? Either way, all of these can happen and have happened with the existing battery. Quote:
You guys need to get real about this though. If you actually want to see this rule changed then suggesting that FIRST partner with another supplier for it and make rules about requiring specific part numbers just makes it more difficult, not easier. It puts the burden on the FRC folks to track down parts, get them donated, include them in the kit, write specific rules about them, etc. That's a lot of work for some already overworked people. An alternative, as I have suggested, is to change the existing rule to fall in line with the example that is already allowed under the batteries integral to COTS computing devices. No one is checking those specific devices or batteries but they are typically checked to make sure they aren't powering any moving assemblies on the robot. Also none of you addressed the existing loop holes that I already pointed out including a flashlight that could be considered a COTS computing device and using super capacitors, which I'm more worried about other teams trying to use than I am a cheap LiPo pack (I'm not actually worried, I encourage it, go use them because they are legal under the existing rules!). It is possible to make all of these items secure and safe though. And with that I'm done with this thread. I could argue with you guys all day about this. I've offered up a solution that makes sense and should make it easy. Stop arguing and actually think about the problem for a while. What I've said isn't crazy talk and is a good way to solve this. Last edited by marshall : 28-06-2016 at 08:01. |
#28
Ok, I do agree a separate power source will limit the impact a brownout will have on your robot, but I am still of the belief that designing to avoid brownouts is just part of the game and that FRC should solve the actual problem by better educating teams on power consumption, rather than just helping one of the symptoms.
#29
My opinion is it would be a better game if you didn't have to deal with controls brown out as it is now. As a complete tangent, an industrial design that had these issues would either separate control & power energy or make the energy source big enough so that is wasn't a issue. With the current rules, a super capacitor would likely make the robot fail the power off test on the robot inspection check list. |
#30
If you make a COTS device that consists of the battery, charger and device you can work this rules set without major changes. I've brought this up before elsewhere on ChiefDelphi and passed that concept around with FIRST engineering a few times. (I reread this topic and note that FrankJ brought this up previously).
So it's possible to make a bundled Raspberry Pi based device with a battery and sell it as a unit COTS. You must sell it to the general public essentially engineered with safety in mind. So the battery boards for the Raspberry Pi do not really cover this because they are not bundled with the system or even enclosed. The risk of *any* lithium based battery is already present because FIRST allows laptops with batteries on the robots, again they could always change that next year, but FRC11 has used a laptop with battery several times. Once the risk exists already it's really hard to argue we can't regulate the hole. Last edited by techhelpbb : 29-06-2016 at 11:19. |
