Go to Post Those four stages will most likely be supplanted with the more aptly named phased approach: "Don't Panic", "Consider Panicing" and "Why havent we been panicing?" - Dan Richardson [more]
Unread 25-06-2016, 19:40
olidem123 olidem123 is offline
Not a community manager
AKA: Olivier Demers
FRC #5618 (PLS)
Rookie Year: 2015
olidem123 is an unknown quantity at this point
Question Is my code good?
Here's a link for my team's 2016 java program: https://github.com/olidem123/PLS5618
I was just wondering if there was ways to improve/make it lighter (other than clarity ).
PS: We are a french canadian team so most of the program is in english. Ask me if you have questions on words.
thx
Unread 27-06-2016, 10:00
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Is my code good?
There is lots to like about your code. It's well organized and generally easy to read. A couple specific comments:
1. We like to use constants in RobotMap.java, organized by kind of interface. We can then print this out and use it as instructions for wiring.
For example:
 	 * PWM   	 */
        public static final int CHASSIS_JAGUAR_FRONT_LEFT = 2;
 	public static final int CHASSIS_JAGUAR_BACK_LEFT = 3;
 	public static final int CHASSIS_JAGUAR_FRONT_RIGHT = 0;
 	public static final int CHASSIS_JAGUAR_BACK_RIGHT = 1;
 	public static final int BALL_SHOOTER_LEFT_SPEED_CONTROLLER = 4;
 	public static final int BALL_SHOOTER_RIGHT_SPEED_CONTROLLER = 5;
 	public static final int ARM_EXTEND_SPEED_CONTROLLER = 6;
 	public static final int CAMERA_TILT_MOTOR = 7;
I'd then recommend moving the declarations out of RobotMap and into the subsystem that owns the device/controller. We generally make each controller/encoder/gyro be owned by exactly one subsystem, and hide the reference inside the subsystem (make them private). This way we know that there's only one place to look for code that changes those entities.
You're almost there with your final references in the subsystems, but they are copies of reference and the actual controller/encoder/gyro is available to everyone.
2. In AvancerHerse, consider using more descriptive variable names:
	int h1 = 950;
	int h2 = 450;
and think about simplifying "!(Robot.bras.distPot() < h1)" a bit:
		if (!Robot.pelle.herseAcotee()) {
			// h1, h2 = hauteur pelle
			if ((Robot.bras.distPot() > h1)) {
				Robot.chassis.reculer(-0.4, 0);
			} else if ((Robot.bras.distPot() > h2) && !(Robot.bras.distPot() < h1)) {
				Robot.chassis.reculer(-0.6, 0);
			} else {
				Robot.chassis.reculer(-0.9, 0);
3. In BrasCommand, you say:
		Timer.delay(0.005);
Wondering why this is necessary here and in the other places in the code. Delay like this is needed only in very specialized cases.
4. In BrasCommand, you didn't put this in braces:
		} else
			Robot.bras.controlBras(0);
For student code, I recommend that every block be enclose in braces as it's consistent and simple to think about.
5. Generally you want the same code in end() and interrupted() -- see Reculer.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 27-06-2016, 11:23
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Not just student code - many company coding standards require this as well, including Java code written for/at Google.
My team intends to use Google's style guide for all our code in the future. Consistently applying rules and formatting will help with integrating and understanding code written by multiple people, and it helps students get used to the idea that they will eventually have to work in an environment where such rules are imposed.
olidem123, it might be a good resource for you too
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 27-06-2016, 18:24
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Just some git/project related things:
I recommend you name your project something that includes the year and/or game. If you're going to be making another robot program next year, having separate names will allow you to store both projects on GitHub. For example, naming it PLS5618-Stronghold-2016 will allow you to make another project next year: PLS5618-WaterGame-2017
Make sure you allow your .gitignore to take effect. On your local copy of the project, commit anything if necessary, then run
git rm -r --cached .
git add .
git commit -a -m "Untrack gitignored files"
Instead of having the command pair InBallon/OutBallon, which are very similar, I think it makes more sense to have a single command handle both, eg
public class MoveBall extends Command {
	public enum MoveBallDirection {
		IN,
		OUT
	MoveBallDirection whichDirection;
	public MoveBall (MoveBallDirection whichDirection) {
		requires(Robot.pelle);
		this.whichDirection = whichDirection;
	protected void initialize() {
	protected void execute() {
		if (whichDirection == MoveBallDirection.OUT) {
			Robot.pelle.outBallon();
		} else {
			Robot.pelle.inBallon();
		Timer.delay(0.08);
	protected boolean isFinished() {
			return !Robot.oi.stick.getRawButton(4);
		} else {
			return Robot.pelle.limitFond();
Similarly, you could even refactor Pelle.in/outBallon into a single function.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 01-07-2016, 22:53
AKA: Olivier Demers
FRC #5618 (PLS)
Rookie Year: 2015
I just edited the program. https://github.com/olidem123/PLS5618-2016
I changed those things a bit and it looks a lot better, still need to test it. Thx
I just removed this part of the program because we found out it was useless.
		} else
Guess I forgot them
I use 2 commands because I found it easier to set up 2 buttons to one command each.
I'll take a good look at that
PS: I sent this post to our mentors for tips for the future years. Thx for all your support!
Unread 02-07-2016, 00:10
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Well you'd have a constructor parameter that specifies which direction to roll the ball.
public enum Direction {
    IN,
    OUT
public class BallCommand extends Command {
    public MyCommand(Direction whichDirection){
// then in OI
Button buttonA = new JoystickButton(stick, 1),
       buttonY = new JoystickButton(stick, 4);
buttonA.whenPressed(new BallCommand(Direction.IN));
buttonY.whenPressed(new BallCommand(Direction.OUT));
