Go to Post Anyways, before we all get worked up over this setup, let's wait and see what details emerge. It can't be as bad as everyone is making it seem. - Karthik [more]
Unread 25-06-2016, 09:04
SndMndBdy SndMndBdy is offline
FRC #3419
SndMndBdy is on a distinguished road
Small Pneumatic Wheels
Hi,
Does anyone know of a place to purchase small pneumatic wheels? I'm looking for something in the 4" - 5" OD range. Smaller would probably be OK too. I ultimately just need an inner and tire (not the hub), but a complete wheel would be fine as well.
Thanks!
Unread 25-06-2016, 09:43
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Small Pneumatic Wheels
I wasn't sure if they were avialable, then I thought about R/C airplanes that sometimes have small pneumatics. Here's one link I found. Try adding a combination of hobby, aircraft, and R/C to your searches.
Unread 26-06-2016, 01:26
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
I did a quick search and found an electric scooter wheel. Not sure of the size.
https://www.amazon.com/Universal-119...1033&sr =1-14
Also found this 5" wheel.
https://www.amazon.com/Dynabrade-944...Y51 YPV82MEFZ
This wheel claims to have a 3.25" hub.
https://www.zoro.com/b-p-manufacturi...f-00505694526f
Links for electronic skateboard
http://www.enertionboards.com/pages/...cnc-alloy-rim/
https://www.google.com/search?q=pneu...-FQGV_VtTlM%3A
Their might also be used by electric wheel chairs or hoverboards.
Another idea is to search for "rubber stroller wheels"
Dave
Unread 27-06-2016, 17:01
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
That does not appear to be a pneumatic wheel.
That is technically an inflatable mandrel for a sanding drum. I don't know too much about these. It could be an interesting experiment, but I think you would have to provide a tread; otherwise it would wear out too fast.
That is the hub width, the hub diameter is 8.75" and the overall diameter is 10"
That looks good. Here are direct links for the tube and tire. It is strange that I can't find any information on that site about the hubs, other than some images of them.
Dave
I think that is your best bet if you need to carry a significant load. Unfortunately, most seem to be 8".
The issue you might see with airplane wheels is that they are designed for takeoff, landing, and some taxiing. Continuous ground use might cause excessive wear. Also, they don't seem like they would be very good at transmitting torque, but I could be wrong about that.
