Go to Post Spouting off without all of the facts is a bad idea. It's also bad to envoke the gods of "Gracious Professionalism" to judge others. - Rich Kressly [more]
Unread 28-06-2016, 19:39
Re: California District Proposal
Originally Posted by Michael Corsetto View Post
3. Venues: There are many HS in California. I know we can get creative and make it work. Its a matter of intelligence over convenience.
Mike, just to be blunt here: when is the last time you were down this way, other than IE 2014?
Yes, there are many HS in CA. There have to be, because of all the people (and all the HS students). But, the biggest question is this:
Of all those HS, how many are able to fit a 40-team FRC event? I would argue that maybe half of them would have the capability just on the "covered open space" requirement--enough space within reasonable proximity for fields and pits. Then you can rule out a few more on the seating requirements--witness said IE 2014 (seating was extremely tight, from what I could see--and so was everything else; they needed more space). Call it a third of the HS's in SoCal would be workable with some minor tweaking and/or major schmoozing with the districts. Still quite a lot, but not as many as you might think.
For ready-to-go regional HS venues (that aren't already hosting), with local team(s) to get a quick manpower boost, I can think of maybe 1-3 offhand, depending on how split you want the pits, all of which have hosted a small-ish offseason. (Adding in a CC or two, that means that I can count 'em on one hand if barely.) For various compromises (lack of local teams, more separation of the pits/field, shorting the seating, or adjusting access), you can get a lot more, maybe up to 2/3 of the HS venues can make it work. The question becomes, how big of a compromise can you actually take before it's unworkable, and people let you know after the season?
Now, that being said, I think it's time to get creative--has anybody, anybody at all, ever tried to host an FRC event in a theater? As in, like, theater where plays are put on? I betcha that a gym-theater combo could do the trick--if they were close enough together and the stage was big enough. And I can think of a couple of those down here that might just barely be workable... Seating, comfy; all seats have good view; plenty of room backstage for queuing... Just need a covered walkway or bagged robots if it's a bit rainy.
And for some reason, folks down here seem to be starting to emphasize the arts a little bit...
Unread 28-06-2016, 20:12
Kevin Sheridan's Avatar
Kevin Sheridan Kevin Sheridan is offline
Kevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond repute
Not enough seats. My high school built a 31,000 square foot theater recently but the seating capacity is only 492 people.
Unread 28-06-2016, 20:13
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I've seen FLL in a small lecture hall. One off-season in Duluth, MN, (GGGT) had a bit of practice space on a theater stage in 2014.
My university has an 80,000 sq ft theater with 1067 seats and a stage that might be just barely big enough. And I'm not even sure where pits could go.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 28-06-2016, 20:17
ASD20's Avatar
ASD20 ASD20 is online now
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Granite State actually put their practice field on the stage in their auditorium. I think an auditorium might be useful for some of those things that aren't too large, but you just can't squeeze in elsewhere. Ex: Practice field, volunteer lounge, table displays, FLL demos. If it has large stage and is close enough, it might even be a decent place to put some pits.
Also, if you are looking for space/tools for a machine shop in a school that doesn't have a team, the drama club is a good place to check. A lot of schools (at least near me) have pretty decent shops that they use to build sets.
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 28-06-2016, 20:49
Pauline Tasci's Avatar
Pauline Tasci Pauline Tasci is online now
Rockets and Robots
FRC #3476 (Code Orange)
Pauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond repute
Hey Eric!
Have you taken a look at the list of so cal venues that were all layed out to be able to fit at least 40+ teams. And thats just schools we know as of now, there is room to grow.
Many of these schools were even looked at for possible OCR and beach blitz locations. When you get rid of the show ready trusses, you actually gain a lot of locations that have the space for great events.
Team 3476 Code Orange- 2014-? ~ Head Mechanical and Design Mentor
FIRST Orange County 2015-? ~Regional Planning Committee Member
Beach Blitz 2016-? ~ Event Chair/Director
FIRST Volunteer-2010-?
Team 589 Falkon Robotics- 2010-2013 ~Captain, Driver, Outreach, Mech Lead
CD Moderator~ Always feel free to PM me.
Facebook
Unread 29-06-2016, 00:42
Originally Posted by Pauline Tasci View Post
Hey Eric!
I have looked. Great, OC and northern San Diego is covered, and there's a couple possibilities in L.A.
Question: What percentage of "looked at" school locations is that? And, has anybody been looking in L.A. (and any other "holes") at other former offseason-event locations? (Might be worth contacting 599--they hosted the Classic for a while, but I can't speak for whether they'd be up for hosting an event these days.)
I've gotten a note from someone who's looked at a lot of venues that maybe a third--at the outside--of high schools in SoCal could actually host a regional.
Unread 29-06-2016, 01:05
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Eric,
Step by step logic here would be really helpful. I'll take it question by question:
1. Do we agree that Northern California has proven to have a sufficient number of already-tested high school venues to support 6 district events in NorCal?
2. Does SoCal needs 9 to 10 district events, assuming 175 teams?
3. How many district events could be covered from the current list, and how many more options do you think we need in SoCal to be "relatively confident" (whatever that means to you)?
4. How many High Schools are in SoCal?
5. Divide that number by 3 (the magic number from your source), how many potential venues to host a district does that leave us with?
6. Does this seem like enough options?
Just like Mark Leon always said, "Do the Math, Save the World!"
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 29-06-2016, 01:49
Eric,
You're the NorCal expert. I'm not going to make any statement here.
Assuming 175 teams, 9. Assuming that no rookies crop up, which would probably put the count to 10.
That's actually rather dependent. There's at least one glaring hole in that list where there's maybe two spots that are going to be difficult (the colleges--trust me, I've got friends that go to one of 'em, getting a college gym is difficult--the exception would be spring break if someone doesn't beat FIRST to it). There's large areas--northwest LA county for one--that aren't covered.
No idea.
Here's where the fun starts, though. Yes, there are enough high schools. (We'll assume that that's the case, because I don't have those numbers. I assume that you have made some effort to get them, or you wouldn't be asking.) The question is: At what cost? One of the possible places that the Torbot mentors were tossing around actually managed to nix an FLL Championship event being held there, simply by deciding that "hey, this robotics group has lots of money, let's charge them"--after said event had been held there previously. We should be out of CIF season, so that's less of an issue (Spring Scrimmage got bumped by a CIF basketball game). You've also got the "skeptical administrator" and the "Sure, pay us an arm and a leg" and the "Sorry, booked up by X, Y, and Z" to deal with. Those can be worked around... but it's going to take a lot more time.
Math doesn't lie: There is the possibility. But you've got to have people on the ground looking. What you've got down here is, largely, one team looking in their area. You need more people looking in more places. Central Coast? Lancaster/Palmdale/Antelope Valley? South Bay/Beach Cities? San Fernando Valley? I've seen people commenting in the thread from those areas. I can't say any of them have put venues in the list. I know I'm not in a position to put down a venue as "yes, this one can most likely host". (If I could, I would.) I know several venues that would probably be disqualified on one or more "obvious" grounds, so if one of those shows up I can put down a note that says "Hey, X is going to make life difficult".
Let me put it this way: I'm not opposed to districts, in the proper time. But when someone who is outside my area, with relatively limited visibility into my area, simply says, "This is the way we want to do it over your area, and with *handwaving here* it'll happen"--I'm really sorry, but I'm going to call you on that. You need more people down here, to get more visibility into the situation down here. They should have been there from the beginning. And the people that are down here are telling you that there are problems--problems that you are blowing off as "That can be fixed, just use some imagination and creativity". Problems that we know can be fixed, but we don't know how much time and effort it'll take over and above what we're already putting into this program just to find a solution, let alone execute it.
Unread 29-06-2016, 02:24
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
I believe the entire point of this thread and the documents shared is to bring awareness of districts to all of California. The documents and posts don't seem like they are trying to force anything onto us nor are minimizing the amount of work involved in making this transition.
Sure it will cost money and will be hard trying to find venues and volunteers, but if other regions can do it, why can't we? If there is a better way of doing things, we need to change. The District model offers more than our conventional regional model and we should do everything we can to switch, no matter the time and effort.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 29-06-2016, 04:35
FarmerJohn FarmerJohn is offline
Pre-Rookie team
AKA: John Reynolds
no team (Turlock Titans)
Team Role: Team Spirit / Cheering
Rookie Year: 2016
FarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond repute
Then why don't you stop complaining about every possible detail and actually try helping for once, Eric? If I have to read another comment about how you "want districts" but don't even try because you think they're not feasible, I'm going to puke. Stop putting down other's ideas because you're so pessimistic about this whole situation. The only thing Michael is doing is pushing for awareness of districts, nobody's telling you what to do. If you don't want to support awareness for districts in California, that's fine, but stop throwing your dirty laundry all over this thread. You're not helping any.
Unread 29-06-2016, 07:26
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 29-06-2016, 11:45
Before this thread devolves into a slew of gifs, lets try to get back on track here
Eric,
I've tried my best to pull together resources from other areas to inform our path forward. I've spoken with many people from other districts in person and on the phone to gather information (special thanks to Jim and Gail at FiM). I've even learned a lot since posting this, and am planning revisions to the proposal to reflect new information.
I currently have friends on FRC Teams 4, 399, and 3476 looking at venues. Dave from 399 has actually been helping for almost a year scouting out venues, but he is out on summer vacation right now.
If it wasn't already clear, I am relying on the community to rally around this proposal and make Districts in California a reality. Our community has been told for years that we can't, but as this proposal evolves, it is becoming increasingly clear that we can! I have been very encouraged by the community response so far.
Please, California, keep it coming. A friend from San Diego posted on this thread a few days ago about venues down there (so much knowledge in that post!), I am hoping he can respond further knowing that cafeterias/MPRs are also options for pits at venues.
If anyone is looking to help and is not sure how, shoot me a PM. It could take as little as a smartphone, tape measure, and spare hour of time
-Mike
Unread 29-06-2016, 12:14
bkahl's Avatar
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Sowwy
Team 125
Team 195
Alumni
Facebook
EWCP
Unread 29-06-2016, 12:19
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I know it at least one of the CHS events this year the pits were split between a cafeteria and a small gym. You can get creative with the pit locations. The more rigid requirements are the bleacher and field requirements.
I know in Virginia there are high schools in certain regions of the state that have much larger gym areas specifically designated for tournaments. I believe there are 4 of them in the state here. Luckily one of them has an FRC team. I don't know if this is also the case for CA but it might be a good thing to look into.
Unread 29-06-2016, 12:47
Thanks for the feedback from CHS!
How large are these "tournament gyms", and how does that compare with a typical HS gym?
With "tournament gyms", do you fit all the pits in the same gym as the field?
Thanks!
-Mike
