Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Unread 28-06-2016, 19:36
CB313 CB313 is offline
FRC #0313
CB313 is an unknown quantity at this point
C++ NetworkTable code error
I'm getting an error in my code
cannot convert 'std::shared_ptr<NetworkTable>' to 'NetworkTable*' in assignment
Can someone help me explain what this means? I'm rather new to coding, and I don't understand what i did wrong. I copied the code from the FRC Network Tables page (Here) And the line
	table = NetworkTable::GetTable("datatable");
is the only one with an error. If it's any help, the whole code is here.
Unread 28-06-2016, 21:25
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Re: C++ NetworkTable code error
Hey!
The getTable method returns a shared pointer. So you have to declare your table as a shared pointer by writing:
std::shared_ptr<NetworkTable> table = NetworkTable::GetTable("datatable");
That should fix that issue!
That tutorial is from 2014 and WPILib has been updated and is now in C++11 which introduced Smart Pointers. I would suggest taking a look at the library :Here!
Team 1403: Cougar Robotics (2015 - present)
Unread 28-06-2016, 23:17
alst alst is offline
Programming Mentor
AKA: Alan
FRC #0830 (RatPack)
Rookie Year: 1830
alst is an unknown quantity at this point
(That link should be this instead - missing a colon.)
Basically, the error means that the type of your table variable is "NetworkTable*" (a pointer to a NetworkTable), while GetTable() returns a std::shared_ptr<NetworkTable>, which can't be converted to a NetworkTable* directly. The place you actually want to change is currently line 9 in your code, where you declare "table" - it should be "std::shared_ptr<NetworkTable> table;".
Unread 28-06-2016, 23:32
Volunteer, WPILib Contributor
no team (Waiting for 2021)
The things posted above are the proper solution. I'll contact the Screensteps people to get it updated.
Team 4488 - Mentor 2013-2016
