Re: 1241 THEORY6 2016 CAD and Prototype Resources Release
I loved your robot this year. I have to say it was one of my favorite tall shooters this year and an elegant intake to boot.
Thanks for these resources and I look forward to seeing you in the future. |
I'll be rifling through the CAD later, but for now:
What changes were made between the wooden prototype and the real bot? Specifically, did anything perform significantly better or worse on one version? Was the wooden prototype better in any areas? Will you be bringing the prototype bot to any offseason events? How were you able to construct the prototype so quickly!? |
Can I ask how you decided what locations on the field to shoot from? While most teams selected either the batter or the Outer Works as their primary shooting location for protection, you tended to set from a variety of unorthodox locations in addition to some of the more common ones.
I'd love to hear the thought process that went into deciding those, or did those come after the robot was already functioning? |
Our primary shot requirement was the batter shot and the just off batter shot, where we would sit off the batter and shoot. We felt that this shot should be our primary shot because we would be closer to the goal, thus also increasing the accuracy of the shot. Our secondary requirement was to ensure we could shoot from where we liked to call the "spy" box. It was in the far left corner of the courtyard where we could press up against both the side rail and opponent wall to shoot from. We did not use this shot come competition much but we felt like this shot would be slightly more accurate than the outerworks shot because we could not be moved once in that location and it was slightly closer than the outerworks. Finally, our third requirement was to shoot from the outerworks. This was the last requirement because its distance to the goal was the farthest (and subsequently the hardest to nail). Combining these shot ranges, we realized this allowed us to shoot from nearly anywhere on the field after doing some calculations and building the prototype. To ensure a higher degree of accuracy we designed a fixed shooter angle with only speed as the varying quantity. Our "diamond plate" shot became our most effective, but in reality it was the same as the just off batter shot. The turret just helped adjust for the angle difference. TLDR: Shot locations were decided based on accuracy (the farther the shot location, the less accurate the shot would be). In addition, the turret helped increase our shot range. Last edited by Jash_J : 29-06-2016 at 08:51. |
That is an excellent prototype! I can see how you had one of the best robots in the world this time around. Out of curiosity, which week did you have that prototype completed?
#7
This robot is so beautiful! What a great resource, thank you so much for posting this.
#8
Very nice! You were fun to compete against in North Bay - tough competition, but if we had to get knocked out of the semifinals, at least it was by the best ones there!
#9
Would you be able to explain the timeline you guys went through to produce your prototype robot so quickly? How many people were involved with prototype CAD? 8 days seems incredibly quick to turn out a fully working prototype (none the less a fully competitive one). Great work, one of my favorite robots this year!
#10
- Read/understand the rules - Scoring analysis and determine game play strategy - Outline clear needs, wants and wishes for what the overall robot should include. Day 2: - Determined detail requirements for each sub assembly of the robot - Broke off into groups and brainstormed various ideas for each sub assembly - These ideas were presented and voted for. Ideas with the most votes are prototyped - Parametric analysis is conducted Day 3-4: - CAD prototype - About 10 students were involved in this, 2 students per subgroup (drive, intake, conveyor, popper, shooter). Day 5-7: - Build prototype Day 7-8: - Test Prototype In order to survive the first week, we included things to look forward to such as a mentor vs student dodgeball game at the end of the first week. We also ensured the students had different food to eat every day when they came in (aka, not just pizza) - they were quite happy about this. ![]() Last edited by Jash_J : 29-06-2016 at 13:33. |
#11
We also discovered that gathering everyone together for a meal was the perfect time to do team meetings and status reports. We didn't do the meals this year due to the nature of our build space, and we really missed that team touchpoint. |
#12
For us, parametric studies include 2 aspects: -Standard Kinematic calculations using excel spreadsheets -Simple 2D sketches showing geometry of systems that can be manipulated easily to show valuable information The parametric studies essentially give us a starting point for the prototype CAD and things to look out for once built. It gives us approximate dimensions for key features, while also telling us which features we have to experiment with/optimize using our prototype. We completed parametric studies for all of our subsystems this year. Shooter: -Projectile Motion spreadsheet to determine wheel rpm, launch angles, height of shooter from floor. -2D sketches outlining ball path through the popper and shooter, showing us pinch values, and dimensions for flywheels/shooter arch etc. Variables to be confirmed using Protoype: Shooter angles, number of wheels, RPM Inake: -Complete 2D sketches showing pivot point and overall geometry of the system, including roller locations, and bumper height approximations.This helped us determine the dimensions/geometry needed to defeat the cheval, portcullis, sally port, and drawbridge -Torque calculations for determining gear ratios in order to allow the intake arm to lift our robot (mix of both 2D sketches and excel spreadsheet) Variables to be confirmed using Prototype: Make sure geometry works + Hooks for drawbrige + durability tests in terms of strengths (we ran our intake prototype into the wall approximately 1000 times to inspect damage) Drive: -Kinematic spreadsheet outlining gear ratios for achieving our desired acceleration and top speed -2D sketches showing initial drivetrain geometry going over all the defences to check for lengths, clearances, and wedge angle. Variables to be confirmed using prototype: Center to center distance between wheels: 11" vs 10" (which we ended up choosing) Hours of work during Prototype Week: Kick off Saturday/Sunday: Approximately 11-12 hours per day Monday - Tuesday (Cadding Prototype): Approximately 8 hours per day Wednesday - Friday (Building Protoype): Approximately 5-6 hours per day Week 1 Saturday/Sunday (Testing): Approximately 8 hours per day Let me know if you have more questions! |
#15
The way I see it, deciding to forgo the low bar must have saved you folks a lot of time in coming up with a prototype so fast.
Your robot along with 3476, 2481, 368 who we played with in Hawaii, etc. proved that the tradeoffs between tall robots and having to go under the low bar were non-existent. This was a great tall shooting robot. Thanks for sharing. |
