Go to Post We do FRC to inspire and to be inspired. - Basel A [more]
Unread 29-06-2016, 17:29
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Applicatiosn of bicycle disk brakes
Doing some research looking into using bicycle disk brakes but am unsure of good applications for them as well as how to adapt them. would love to see how teams make them actuate to and from being a brake as well as how them are attached to mechanisms. Thanks (pictures would be appreciated)
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 29-06-2016, 17:38
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: Applicatiosn of bicycle disk brakes
In 2014 we used one. We actuated it using a piston and it was actually attached to a bike hub, like it was designed to, that we used to winch back a puncher.
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
2363 at least prototyped with a disk brake last year. Not sure if it ended up in their final design: https://www.youtube.com/watch?v=9QmJ3KatBw4
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 29-06-2016, 17:42
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Here's how we used a disc brake on our 2015 robot "Guillermo"s elevator. The brake allowed us to hold a stack without having to keep current on the motors, and with a faster gearbox than would otherwise be necessary to prevent backdriving.
Mounting was reasonably easy. We modified an Andymark hub (slotted the holes a bit) to match the rotor hole pattern then slid the rotor over the end of a hex shaft. We made up a plate to mount the caliper. The cylinder (a 3/4" bore, 2" stroke iirc) was mounted on a bracket remotely, connected to the caliper with a bit of brake cable and housing.
I think 1678 (and probably others) used a disc brake on their climber this year. We considered one too, but ultimately just went with a single use latch (since you only climb once in a match.
Name:	2015-03-19 12.34.35 (1).jpg
Last edited by nuclearnerd : 29-06-2016 at 18:41. Reason: attached picture instead of hyperlink
Unread 29-06-2016, 18:10
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Our elevator brake from 2015.
Unread 29-06-2016, 18:15
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We used one last year on our elevator (thanks 2363!) too prevent backdriving. This let us run a 24in/sec elevator with two RS775-18v without overheating issues, although we did lose some gears on the Versaplanetary dual input later in the year.
We also used one this year to hold our angler in place, but there were many issues with it that caused it to be ineffective. It may have just been the brake we used or manufacturing tolerances.
Unread 29-06-2016, 21:40
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
In 2015 we incorporated a pneumatically actuated bike brake into our robot.
The disc was coupled to the belts that drove the lift. The software was setup to automatically engage the brake when the commands to the motors that drive the lift were below a value that would cause motion (that way we didn't have to explicitly engage and disengage the brake with every command).
The brake and caliper are this one: https://www.amazon.com/gp/aw/d/B003W...IIL&ref=plSrch
Renders from our CAD model here:
http://imgur.com/a/17HN6
It would also be worth checking out 971s robot from the 2014 season: https://picasaweb.google.com/m/zoom?...portHeight=416
http://team2168.org
Last edited by otherguy : 29-06-2016 at 21:59. Reason: Added details on brake and link to 971s design
Unread 29-06-2016, 23:12
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
In 2014 we used a disc brake on our shooter winch. We wanted a fast cycle time between shots, less stress on our dog shifter while firing, and most importantly control over the shooter for safety.
The cable coming from the gearbox was connected to a locking piston mechanism that was larger than it needed to be but it did the job well and was a designed by some freshman students and made primarily on a bandsaw and drill press.
Pictures can be found here.
Video of them in action here.
1058 PVC Pirates 2016 - xxxx
Unread 30-06-2016, 03:02
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
I'm pretty sure 1678's 2015 robot used a disc brake to keep their elevator at a fixed hight.
Unread 30-06-2016, 08:16
ZeroGAdam's Avatar
ZeroGAdam ZeroGAdam is offline
AKA: Adam
ZeroGAdam will become famous soon enoughZeroGAdam will become famous soon enough
In 2012, my old team, 2180, utilized a disk brake on our rear wheel to aid in balancing on the competition bridge with our robot which was basically a 4x4 . I remember that year, once we showed it off in our first few matches, teams would always come to us to make sure that we would balance with them on the center CO-OP bridge. Ahh, those were the days. I'll see if I can find any pictures because it actually was a stupid simple system which included stock bike parts, some fishing line, and a servo. Only a little force was required for our entire robot to be locked in place.
NEFIRST Game Announcer 2015 - Present
Team History
FRC Team 190 2014 - 2015
FRC Team 2180 2010 - 2014
FRC Team 381 2002-2008
FTC Team 221 2010-present
Unread 30-06-2016, 09:45
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
We used a disc brake in 2015 like many teams to hold the position of our elevator without having to stall the RS775 motors that powered it.
We purchased this kit off Amazon and mounted 1/2" hex versahubs to the rotors. We then used a small pneumatic actuator to pull on the brake cable whenever power wasn't being applied to the elevator. It was incredibly easy to set up and install from a mechanical perspective and we never smoked an elevator motor during our matches.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 30-06-2016, 21:50
DonRotolo's Avatar
Back to humble
FRC #0832
I'd consider a pneumatic cylinder - not much stroke needed - that is Brake On in an Unpowered state. Many bike brakes use hydraulics, so I'd be wary of that, but bowden-cable type are dandy. Use latex tubing to pull the brake ON, and a cylinder big enough to fight the latex and push it OFF. Release the air and it clamps down.
Unread 01-07-2016, 18:36
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
It did make it into the final design! Thanks for the shout.
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
Unread 01-07-2016, 18:50
AdamHeard's Avatar
Lead Mentor
Anyone know the weight of the brake caliper assemblies posted here?
Unread 01-07-2016, 19:07
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Here ya go, buddy
2001-2004: Team 100
2006-Present: Team 254
