Go to Post Inventing rocks. I think we've all learned that through FIRST. - Billfred [more]
Unread 06-30-2016, 11:11 AM
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
RobotBuilder and first Java code.... help needed
Good morning,
transitioning to Java from Labview. This is our first attempt in setting a practice bot using Java.
We installed Eclipse, Java and all driver stations stuff. So far so good.
We used Robot Builder plugin and create a simple project with 4 motor drive subsystem and a compressor subsystem.
We have Left Front, Left Rear, Right Front & Right Rear. Using Talon SRX with CAN to drive 4 CIMs on the wheeled drive chassis.
I am successful in downloading the code on the roboRIO, enable test mode and open the smartdashboard to test the device. Each motor display as expected on the Smartdashboard.
Left Front and Right Front work just fine. Each one has the PercenVBus selected and we apply percentage using the slider.... motor is moving fwd/bwd as expected....
Left Rear and Right Rear are not moving... The LEDs on the Talon SRX are changing as they should.
I swapped the motors... Left Front became Left Rear.... nothing is moving... LED are working as expected... i see flashing green when we command to move fwd and flashing red when we command bwd....
Kinda stuck on why it behave this way... any idea would be appreciated...
Thanks in advance.
Unread 06-30-2016, 11:52 AM
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: RobotBuilder and first Java code.... help needed
It looks like you have a physical disconnect between your rear motor controllers and your rear motor. I could be wrong, but if the lights are indicating the desired direction, that is the output. Try using a multimeter at various points on the connection between the motor controller and motor to find the problem connection. This doesn't sound like any sort of programming issue. To make sure this theory is correct, you can go into the web dashboard on the Rio (go to roborio-5860-frc.local in Internet Explorer), and run a self test on one of the affected SRXs while you putting the desired control into it.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 06-30-2016, 12:13 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
To verify that hardware is the problem, check the output current of the talon. It should be on the test page, otherwise use the getOutputCurrent method. If the current is zero, you have a bad connection somewhere.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
If you swapped the motors and the problem remains and since the lights on the motor controllers are functioning properly, it means the problem is either in the wiring, most likely the connectors or the motor controller itself. I assume you are using Anderson connectors, you may examine the contacts inside the connectors. Sometimes, the contacts may have slipped out on the controller side. If everything still looks fine, you may want to replace the motor controllers in question.
Unread 07-04-2016, 10:53 AM
Coach Seb's Avatar
Rookie Year: 2015
Thank you everyone... dahhhhh.... wiring issues... its now fix and let's move to the next issues which is controlling with joystick...
Unread 07-06-2016, 05:01 PM
Ouroboroz Ouroboroz is offline
AKA: Kevin
FRC #2554 (The Warhawks)
Ouroboroz is an unknown quantity at this point
So what exactly is your issue with the joystick?
To use the joystick to move you can either pull axis values from the Joystick or some methods like arcadeDrive directly take the Joystick object as a parameter.
