#21
Re: Cutting Tetrix gears
Marsh Collins did a long article on building a metal shaper which for me is on page 110 of "Projects 8, The Home Shop Machinist" hardcover. A bigger shaper than the hobby size one from the link provided earlier to Martin Model. It is attractive to me to use just a shaper to make gears because it is very predictable in operation and I make so few. Hobber costs add up. There are plenty of tips in "Tabletop Machining": https://www.amazon.com/Tabletop-Mach.../dp/0966543300 Page 226 for example they cut a helical gear. The Sherline 8700 stepper driver rotary table manual has a section on gear cutting. Now that I scrounged the stuff in grabbing radius .Here is a HSS bar in a fly cutter body using a 4th axis on a desktop mill to make a replacment gear: http://www.homemodelenginemachinist....ead.php?t=7246 Keep in mind if you do that you better be darn sure the fly cutter body is mounted firmly. The link above is a manual indexer but that technique works on a CNC 4th axis as well. Will update when I get to my library later... Last edited by techhelpbb : 07-01-2016 at 11:22 AM. |
