Go to Post I'd rather have a target on my back than be invisible to the competition. - Chris is me [more]
Unread 28-06-2016, 14:39
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Locking gas springs - legal?
After a quick review of the manual, I'm inclined to say that locking gas springs are legal. I just wanted to poll the forum before we started sinking a lot of effort into the idea.
We used a gas spring in our 2016 robot to balance the (long) intake / scaling arm. We're hoping to improve the setup by replacing the gas spring with a locking version (unlocked with an air cylinder pulling the remote release) to hold the arm angle without motor current.
These are the types of products:
http://www.mcmaster.com/#gas-springs/=131wqob
http://www.geminigassprings.com/inde...hk=1&Itemid=12
http://www.bansbach.com/index.php/en...elease-systems
Unread 28-06-2016, 14:58
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: Locking gas springs - legal?
I don't see why they wouldn't be legal. Is there a particular rule you are concerned about?
Standard disclaimer about this being based on last year's manual.
Unread 28-06-2016, 15:07
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I would assume they were legal, per the 2016 rules - They are a closed loop gas shock (R35 D). Out of curiosity, what sort of mechanism causes them to lock into place?
2016: Lake Superior WFFA
Unread 28-06-2016, 15:32
AKA: Brendan Simons
FRC #5406 (Celt-X)
On the Bansbach page, there are a couple versions. Type B uses a valve that interrupts gas flow between one side of the cylinder to the other. They call this "spring locking", since the gas is compressible, and the cylinder locks with some springiness. The other types put the valve in an oil reservoir, which locks the cylinder rigidly (in one direction or the other or both).
The only concern would be whether the latter types would contravene R9, but I would tend to believe they don't count as "hydraulic devices" in the same way as they currently don't count as "pneumatic devices" (R77 blue box) for the purposes of the safety rules.
Unread 28-06-2016, 16:20
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Until this Q&A I would have said that would be legal. But with the Q&A the GDC says maybe not.
Q. R35 allows for "closed-loop COTS pneumatic (gas) shocks" on the robot. Would a closed-loop "gas spring" that contains oil within its sealed housing meet the requirement of R35 and not violate the R9 ban on hydraulic fluid?
FRC4276 on 2016-01-28 | 2 Followers
A. No, a shock containing oil, other than minuscule amounts for lubrication, is not considered a pneumatic shock.
Unread 28-06-2016, 16:27
AKA: Brendan Simons
FRC #5406 (Celt-X)
Well that sucks. These would have been such a useful product (easier to integrate than disc brakes for holding arms in place). Thanks for digging that QA up though. Is there a way to appeal for rule changes in future years... (The way quick exhaust valves were finally made legal this year R77)?
Unread 28-06-2016, 16:45
Mentor, LRI, MN RPC
I think the described "spring locking" would be ok, as there's no oil involved. The other type, with oil, probably not as FrankJ pointed out.
Personally, I don't see them changing that in the future. Having a reservoir of oil on a robot really is only asking for trouble - a good impact or two and the thing splits open, releasing oil over your robot, other robots, and the field - can you imagine trying to get that cleaned up out of the field carpet so it doesn't impact future matches?
Your best bet at getting anything legalized in the future, I think, is to keep asking questions about it on the Q&A each year. Carefully think through the consequences to the field, other robots, and general safety and of ways rules could we written to mitigate those consequences, without requiring a significant amount of engineering from teams - for example, see R69.
Unread 28-06-2016, 16:59
AKA: Brendan Simons
FRC #5406 (Celt-X)
A burst gas spring would be very bad, whether or not there is any oil present. these things store nitrogen at more than 1000 psi - any damage would make for a pretty scary bang! Does the oil lock make the risk of failure greater? What if we could prove (by manufacturer testing for instance) that the locking valve would fail under pressure before the cylinder did, protecting the integrity of the housing?
(these are hypotheticals of course. If the QA were open, I'd direct these questions to the GDC)
Unread 28-06-2016, 19:16
The other method would be to email frcteams (at) firstinspires.org with question, suggestion, and/or "what would it take to have these considered legal".
Unread 28-06-2016, 19:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
FIRST takes both safety and inspectability by crews who don't quite know what they're looking at seriously. If you want to propose such a rule to FIRST, I suggest trying to craft a rule that both ensures safety and is inspectable by FRC inspectors at the current base level. If you can't meet both criteria with the same rule, the chances of adoption go way down.
Unread 29-06-2016, 09:19
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Although it is clear that First does monitor CD, Erich's suggestion is the official path for rules change suggestion per numerous mentions in the Q&A. I think the Q&A response was poorly thought out. Poor definitions make the RI's job difficult and leads to different inspectors making different decisions. Shock absorbers use oil. Most COTS "Gas springs" use more than an minuscule amount of oil. Here is a CD discussion on the Q&A.
In either case you are far more likely to pretzel the rod than to rupture the cylinder.
Unread 29-06-2016, 12:50
AKA: Brendan Simons
FRC #5406 (Celt-X)
To wit, here's the response from Bansbach I received today. The short answer is in most types the lock will fail before the cylinder, and a safety overload release can be specified:
In general terms the following describes the different locking springs
For K locking gas springs, if you exceed the locking force in compression, the valve will open and the gas spring will compress. Please note however that the valve will close back up if the force is removed and the spring will lock again.
For P locking, the same applies as the K locking but in the reverse directions. In this case, exceeding locking force in extension results in the valve opening
Please note however that in both cases, overloading the gas spring degrades the sealing mechanism of the spring and you may eventually have a failure where the unit no longer locks.
For KX locking, the force listed is the maximum force in both directions based on the material strength of the locking components. We advise you never exceed or plan to exceed the listed locking force in any of the gas springs as listed in our catalog.
Locking gas springs are not meant to function as shock absorbers.
If you need a gas spring that has a safety overload we can actually provide that as an integral part of the spring. We refer to this type of gas spring as a V-variation of the locking springs. For example, we can have a spring whose regular locking force is 1000N and if exceed will allow movement until the force drops back down.
As suggested, I will write an appeal sometime this summer and send it to FIRST HQ. In the meantime we'll unfortunately abandon this approach to modifying our robot for off-season events.
Unread 29-06-2016, 13:04
AdamHeard's Avatar
Lead Mentor
I guess I'm missing something, how are these different in terms of the rules compared to the traditional gas springs teams have been using?
There was a QnA during season that confirmed they are legal even though they have a small amount of oil inside for lubrication and sealing.
Unread 29-06-2016, 13:23
Mentor, LRI, MN RPC
Adam, at issue is the "oil reservoir" some of them use - that is not a "minuscule amount for lubrication" as specified in the Q&A ruling.
Unread 01-07-2016, 18:31
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
My team that I mentor LOVES stored energy! When I was a member in 2013, we first tried with Kraken, but we were unable to get that to work, so we ended up attempting Narwhal, which sadly was deemed unsafe as our winch cable snapped a couple times during retraction (both used non-locking gas springs, so we had to get creative and design our own locking mechanisms).
This past year we got some of the locking gas springs, which were pretty sweet in that we didn't have to worry about having to design a mechanism to lock them when they were charged. Both years I think we used a maximum of 500lb gas springs (on Narwhal we had 1,400 pounds of gas springs - 2x500lb & 2x200lb). Have fun with one of the safest forms of energy around! Once you release it, make sure there's nothing in the way, because it won't stop once it's going
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
