Re: Using PTO Hub in Transmission Gearboxes
Neat idea! What's stopping you from putting the bearing in the gear instead of the PTO hub?
I kinda realized that this is a bit dumb; if you're going to make your own gearbox, then by that same process you might as well custom machine a gear to have the dog profile (unless somehow it's preferred to minimize machining time as much as possible) |
Cool Idea! I agree it might be heavy/unnecessary for a final gearbox but I think this would make an awesome prototyping tool.
It's way easier to machine gearbox sideplates or gearbox shafts than it is to index and machine even a COTS gear with non-revolved features like dog teeth. They're both certainly possible, but it's just more effort to get the machining on the gear concentric than it is to mill out a gearbox plate from stock. I'd probably do something like this if I wanted to use a different dog gear; it's a good solution I think. I don't see why this wouldn't work.
I wonder if you could actually print this hub? Not out of ABS or PLA, but something more substantial, like Ultem 9085 or even 1010 if you can get your hands on the blasted stuff. I know that if you shift at the appropriate times for whatever ratios you have, the forces on the god would be much smaller, but they'd still be significant. Maybe having a pretty slight first reduction so that the shifting occurs at a higher RPM with less torque?
It's probably not practical to print it, but it might be interesting. |
